idle issue fixed
Old Jan 10, 2006 | 05:14 PM
chelo's Avatar
Default idle issue fixed
I wanted to give an update on my idle problem, since I like to find the resolution to problems when I do a search in the forum.
A while ago I posted a question about an issue I had with my Disco I. Basically the problem happened when it was warm outside and I have been driving around doing errands. I would go to start and the engine couldn’t hold idle and eventually died, unless I gave it some gas. It did not happen at stop lights, just when I started it.
The problem was the stepper motor (IAC valve), when I pulled it out it was completely cover with carbon. I soaked it in some throttle body cleaner and cleaned it all out.
Problem fixed.
Regards,
Chelo
Old Jan 2, 2009 | 07:16 PM
alemurill's Avatar
Default RE: idle issue fixed
great info man. I have the same problem. Can you tell me where is located the stepper motor (IAC valve)?
thanks a lot
Old Jan 2, 2009 | 07:43 PM
Glad you reported the fix.
I also hate open ended posts.
jglennaz
Aug 11, 2014 10:46 AM
Flyin2jz
Dec 28, 2013 11:56 AM
vpadferg
Jan 19, 2013 09:41 PM
tweakrover
Nov 16, 2010 09:43 PM
westernsun
May 27, 2006 04:24 PM
