Idler pulleys
- Crankshaft pulley ERR5085, ERR7372, LHG100670, LHG000060
- Tensioner and Pulley assy: Gates #38245, Dayco #89287
- 100mm or 90mm tensioner pulley only: LR #131070,Gates #36102 steel, *not plastic Dayco #89054! (Double seal bearing #6203-2RS, 17mm ID x 75mm OD); torque to 33 Ft/Lbs
- 80mm idler pulley (between AC compressor and steering pump): LR #PQR101150 steel, Gates #36275 (Double seal bearing #6304-2RS or NTN bearing #6304LLU, 20mm x 52mm x 15mm); torque to 37 Ft/Lbs
- 70mm idler pulley (near tensioner): LR #PQR500060 steel, Dayco #89052 steel, Duralast #231052, (Double seal bearing #6203-2RS, 17mm x 40mm x 12mm); NTN & SKF are two good bearing brands; same bearing for alternator; torque to 37 Ft/Lbs
The following 6 users liked this post by JUKE179r:
anbran (03-30-2021),
Externet (08-26-2022),
gecko951 (08-17-2023),
kdscott100 (07-31-2023),
mollusc (03-26-2021),
and 1 others liked this post.
Hi, I bought the Dayco 89287 automatic tensioner assembly and the Gates 36301 (H3 steel pulley). So now onto the driver's side and the Gates 36275 ?? Amazon says it will not fit..... Sorry to be so daft. Being North of 49, I only order from AB or Lucky8 if the bill is over a Benjamin. Thanks. Cheers,
order from AB and save the headache
Hummer H3 pulley
Ok, I note the shape/size of the bushing of the pulley results in a 10 mm loss of bolt length. Did you put another bolt 10 mm longer or do with the OEM one from the old unit? (I note there would be about 10mm of bold instead of 20MM thanks.
