Idles better after car wash
Old 09-08-2022, 09:37 PM
Trailmix's Avatar
Default Idles better after car wash
I've had my 04 for a few months. Shes got 124k miles and I've added about 1k. She's idled a bit rough since I got her. Rpms are at about 750.
Today I went through the car wash - typical automatic style where car is in neutral and it pulls u through brushes, water, suds and a dryer.
When I exited, the idle was smooth as silk. Was still at 750 rpms. I had to keep checking to see if car was even running. I loved it, but it only lasted about 10 minutes and gradually became rough again. Obviously the wash did something that wore off.
Any ideas??
Old 09-09-2022, 04:19 AM
mln01's Avatar
Do you say the engine idle has been rough. Has the Service Engine Soon light been on?
Old 09-09-2022, 06:05 AM
tune up recently ? plugs wires maybe coils, check for vaccum leaks etc
Old 09-09-2022, 06:31 AM
Trailmix's Avatar
yes, it's idled rough since I bought her a few months ago. But became smooth as a new car the second I left the car wash. Then rough again 10 min later.
Service engine light has been on for months, due to thermostat code P0124. Not related. (Edit: Correct code is P0126)
Old 09-09-2022, 07:13 AM
jastutte's Avatar
isn't P0124 a Throttle Position Sensor code? it might be related.
Old 09-09-2022, 07:59 AM
Trailmix's Avatar
I might have typed the wrong code in my first post. ill confirm later today. (Edit: correct code is P0126)
Old 09-09-2022, 04:09 PM
Sandman614's Avatar
Possibly cooling related, ran smoother when being sprayed with cold water. lower intake air temp, Radiator cooling more?
Old 09-09-2022, 05:51 PM
Trailmix's Avatar
I dont think thats it. per the Ultraguage, the truck runs cool at 175 to 180 degrees. 188 at the highest.
Old 09-10-2022, 06:08 AM
NZPablo's Avatar
Try it again. See if you get the same result or was it just a coincidence. Check to see if you're getting any water in the engine compartment after the wash. Hard to see how water anywhere else would make any difference!
Old 09-10-2022, 05:36 PM
Trailmix's Avatar
This is the first time it's ever idled smooth in the few months ive had it. Now that the car wash "knocked it" smooth for those 10 minutes, I know it should be smooth. Something is wrong with it.
Any idea what a car wash coulda done to temporarily fix my rough idle???
Quick Reply: Idles better after car wash
