ignition coil
Old Feb 19, 2008 | 08:57 AM
Discochick's Avatar
8th Gear
Default ignition coil
I have a 2003 discovery.last week it would start and then cut off in les than minute.
Garage said it was a crank sensor. This week it started and then it sputters and hesitates when you put it into drive and the service engine soon light flashes nd then it stayed on. I barely made it to the shop.
They say it's the ignition coil.
They replaced the engine not even a month ago and every since it has been one thing after the other.
I want to know if the ignition coil could cause the problem with it not accelerating properly and the service engine soon light to come on
Old Feb 19, 2008 | 10:31 AM
Default RE: ignition coil
You need a new shop that is not into guessing what's wrong.
If the coils are bad, you will get misfire and coil failure faults, is your check engine light on, if so what are the fault code numbers?
If it is the crank sensor, you may or may not get a fault if it is failing.
Call me and lets talk about your truck.
303-862-7680
Colorado any day before 8 pm
trialrun
Nov 11, 2014 08:41 AM
b_woodroaster
Nov 5, 2010 08:54 AM
GoldDiscoII
Jan 31, 2009 09:09 PM
CandiMan
Aug 6, 2008 06:08 PM
GoldDiscoII
Dec 3, 2006 12:06 PM
