ignition coil fuse blowing
Old Oct 23, 2006 | 01:18 PM
GoldDiscoII's Avatar
Default ignition coil fuse blowing
Problem is with an 01 Disco II with 53,300 miles. Stopped by the coffee shop and when I came out it turned over fine as normal but no start. Got towed home by a buddy and found out that the ignition coil fuse blew. Problem is when it was replaced, it blew again. Im going to check the coil now. Grounding issue of some sort maybe? Any suggestions appreciated.
Old Oct 23, 2006 | 01:35 PM
Default RE: ignition coil fuse blowing
So you have my curiosity up, let me know wha you find.
Just out of curiosity, have you tried to reset the inerita switch?
Mike
Old Oct 23, 2006 | 01:50 PM
Crap. If I have your curiosity, then that cant be good. Inertia switch. That sounds like a good idea. Where would I find that? Thanks.
Old Oct 23, 2006 | 02:15 PM
Look on the firewall, passanger side, it is a large black switch, push it and reset it, then try a new fuse.
Mike
Old Oct 23, 2006 | 02:30 PM
Reset the inertia switch and disconnected both coil packs and its still blowing. Glad I got the big pack of fuses.
Old Oct 23, 2006 | 02:35 PM
You have to have some sort of a ground or short problem, I don't even know where to tell you to look.
Mike
Old Oct 23, 2006 | 02:39 PM
Ok. Thats what I thought. Thanks anyway, I'll keep pluggin along. Hopefully I can figure something out.
Old Oct 23, 2006 | 03:54 PM
Well good news for now at least. I pulled the underdash fusebox and disconnected the ignition harness as well as some of the others so I could get a good look up in there. Put it all back together and she started right up. I also pulled one of the ground wires off by the battery and retightened it. Not sure what did it but something worked. Hopefully its permanent but well see.
ETA: Even though its fixed, it still cost me money. I'm tiling my bathroom and had the toilet sitting my garage. My bracket fell off my worklight, I bent over to pick it up, bumped the crapper and...yep. Broken toilet all over the garage. Oh well, needed a new one anyway and a running Disco is worth a new john I guess.
Old Jan 31, 2009 | 09:09 PM
kraelo's Avatar
hahahahaha........
sry but it just sounds like a few of the things i've gone through, rover breaks, i break other things fixing rover, rover still won't run right :S
Jameslandrover110
Defender
Feb 18, 2011 02:46 PM
pedro_malo
Sep 8, 2008 03:51 PM
mark 07
Dec 24, 2007 03:34 PM
jmt
Dec 23, 2007 06:16 PM
MalcySP
Jul 12, 2006 05:45 PM
