Ignition/Starter 95 Disco
Old Jul 22, 2007 | 05:21 PM
Steve D's Avatar
7th Gear
Default Ignition/Starter 95 Disco
Bought my 1995 Disco new, and have taken it over hill and dale for 143K. Lot's of fun.
Last year, the ignition got wierd. Sometimes had to turn the key ten times before the starter engaged. Then it would run fine for weeks on end. had the dealer mess with it a few times, but nothing definitive. Starter and starter wiring harness were replaced months before.
Got a Hybrid in January to save gas, and didn't drive the Disco much. This month, I wanted to take her for a trip, but battery was dead. Put in new spark plugs, changed oil/filter, and charged up the battery.
Now, I am back to the possible ignition problem. Turn key, and get the little clicky sounds under the glove box, but no starter engagement. Tried turning key a bunch of times, but no action.
Wonder if putting in new ignition will do the trick, and whether I can do it myself? Doesn't look too hard---a few bolts and cables?
Trying not to spend too much on my "extra" truck, but sure do love it.
Any ideas appreciated.
Steve Crofton, MD
Old Jul 22, 2007 | 07:57 PM
Landzu's Avatar
Default RE: Ignition/Starter 95 Disco
Two things maybe wrong.
The easy one battery post are dirty, they can and docorrode between the post and terminals, just take them apart and clean.
You can get power but not the amps a starter needs.
(radio code)
The other is the starter is/has-going/gone out.
Old Jul 28, 2007 | 01:51 PM
Steve D's Avatar
7th Gear
Thanks. I'll try both.
After reading the site, I was afraid I might be dealing with the dreaded spider thing and have to tear out the dash board to solve it.
Steve
Old Jul 28, 2007 | 03:47 PM
The battery that failed won't recover and take a good charge, go have it tested, pretty sure I am right, you may be the proud owner of a new battery.
Mike
Old Jul 29, 2007 | 02:17 AM
dow's Avatar
dow
sounds like your starter has "hot spots". this meaning that the starter has to be jarred for it to move to a good contact point in the starter motor, or it finally gets enough juice to arc to a good contact...
buying a new starter is ideal, but you CAN repair hot spots on a starter with electrical parts cleaner, but this requires removing and disassembling the starter. disassembling it is the easy part, putting it back together is something entirely different...
good luck
Gimebakmybulits
Jul 14, 2014 05:57 PM
will rocket
Off Topic
Sep 12, 2013 06:23 AM
1998DiscoverySE
Jun 27, 2012 01:56 PM
johnkbl
Apr 23, 2012 07:49 PM
brian891
Sep 2, 2009 10:57 PM
