I'm going to buy Disco
Old 06-08-2008 | 04:40 PM
Default RE: I'm going to buy Disco
When I was looking I found both. And the spring converstion kits run around $1,000.
Old 06-08-2008 | 05:52 PM
korostik's Avatar
Is there any major difference between Discovery and RangeRover? (I don't care about interiorend exterior.)
Which is better?
Thank You.
Old 06-08-2008 | 05:58 PM
They have the same chassis and driveline. The Disco is better because it has fewer problems. EVERYTHING in the RR is electricily controlled and thus prone to failer. I almost bought a RR but then bought my DI instead. Not to mention the RR has the air ride on all four corners.
Old 06-10-2008 | 06:58 PM
Taliesin's Avatar
Not attempting to threadjack, but I also am going to be buying a Disco in the near future. My choices at this point are narrowed down to a Discovery I XD or a Discovery 2. Are there pros or cons for either model? The XD is a 97, the DII is a 2000.
Old 06-10-2008 | 07:20 PM
The DI is easier to work on, more mechanical than electrical.
The DII has better ergonomics.
You are going to get different opinions on this, those with the DII LOVE them and us with a DI LOVE them.
Here is one example-The front wheel bearings on a DI can be replaced, two bearings per side, one inner and one outer. On a DII you have to replace the whole hub assembly. Parts and labor on the DI $100 per side, DII $400 per side.
On the DII the double cardon joint on the front dirveshaft MUST be rebuilt and have greasable u-joints installed, the DI does not have a double cardon joint and comes with greable u-joints on both driveshafts.
The transmission on the DII is electonic giving you better and smoother shifts, the DI has a regular old transmission, you know the kind, the same one that your dad had in his Buick 20 years ago.
A tune-up on a DI takes about a hour, a DII takes all day.
You need to drive both, call your insurance agent and get a quote on each. Are you going to work on it or your mechanic?
The DI has a Cental Locking Differential, the DII does not* (*some do, depends on the year).
It all comes down to personal prefferance.
TATZOO
06-10-2013 06:22 PM
dwilliamsceg
06-07-2010 10:17 AM
LRScott
07-17-2009 01:05 AM
traffictech870
02-07-2008 12:05 AM
usmc_grunt
06-30-2007 12:04 AM
Quick Reply: I'm going to buy Disco
