I'm losing my marbles here
Old Oct 9, 2021 | 07:12 PM
The Deputy's Avatar
You should verify these temps with a IR gun...sender could be bad.
Especially, if you had no boiling over of reservior at 242.
Old Oct 9, 2021 | 11:41 PM
DiscoRover007's Avatar
Sounds like you may have air in the system. Best thing to so though is to refresh the system with a brass propeller water pump, heavy duty fan clutch, and inline thermostat mod. Its not cheap and it takes some work. But if you want to cut the bull**** that is the stock cooling system, this is the way to do it. Your headgaskets will thank you for it, and live longer with idle temps never hitting 200 on a normal day.
Brandon318
Oct 17, 2020 09:44 PM
Mstudt
Dec 28, 2019 12:36 PM
evansmade
Mar 18, 2019 08:26 PM
DiscoRover007
Jan 3, 2013 10:12 PM
Snafu / Disco Fries
May 21, 2012 11:24 PM
