I'm in trouble
Old Oct 4, 2012 | 11:04 AM
New2LR's Avatar
Found a place to scan, will post as soon as I have the codes.
Old Oct 4, 2012 | 11:52 AM
New2LR's Avatar
Ok, it was scanned with two scanners.
The first was a MaxiScan, and showed the code P0308. It apparently looked like there were a total of three codes, but it only showed one, so he tried another scanner.
The second scan was on an EVO scanner, and only showed the P0308 code.
The guy scanning it thinks that's the only code, since it's the only one that showed on two scanners.
Old Oct 4, 2012 | 12:00 PM
lr2001silver's Avatar
Banned
Misfire on cylinder # 8
Old Oct 4, 2012 | 12:17 PM
ghengis86's Avatar
hmmm...make sure plug and wires are in good shape. Wonder if you're getting spark on that plug/wire? Injector fouled? But that would probably lead to lean codes and a clean plug.
There are some service places that have BG products/services. Perhaps a 44K treatment is in order?
1.Jacobsen Pontiac Buick GMC
2727 Highway 97 North View mapKelowna BC CA V1X4J8Services available:
2.Orchard Ford
2741 Hwy 97 N View mapKelowna BC CA V1X 4J8Services available:
3.Turner Volkswagen Audi
1717 Harvey Ave View mapKelowna BC CA V1Y 6G3Services available:
Old Oct 4, 2012 | 12:31 PM
coors's Avatar
This is a shot in the dark, but did you recently drive the truck through any heavy rain or deep submersible puddles? I took my truck through a DEEP creek bed (water level just below the doors) and got misfire codes, truck running rough symptoms. Gave it a day to dry out and she was back to normal. Something got wet (maf, O2 sensors, cats, something) the truck just wasnt happy.
Old Oct 4, 2012 | 12:54 PM
br0keit's Avatar
Time to utilize your AAA premier membership and its lovely 200 mile tow.
But seriously...as stated already...find a good indy mech.
ps. 308 is a cylinder 8 misfire which makes sense with the issues you've been suffering.
Old Oct 4, 2012 | 01:19 PM
ashtray's Avatar
I'd try a battery restart. Just saying. It is a simple solution that sometimes works wonders.
Old Oct 4, 2012 | 01:27 PM
hilltoppersx's Avatar
what?
check cyl 8 for spark. then check for shorts with a water bottle. you might just need new plugs and wires. did you lose any coolant? is the oil milky?
Old Oct 4, 2012 | 01:34 PM
ashtray's Avatar
Originally Posted by hilltoppersx
what?
Resetting the ECU by unplugging the battery for 2 or so minutes. It'll clear all codes, and if it said it was throwing 3 but only showing 1, this might help there as well. But that is just the first thing I would do. From there I would do the plug and wire.
Old Oct 4, 2012 | 01:37 PM
Banned
Obviously you don't know anything about rovers... don't ever
Tell anyone on this forum to try to reset any codes by disconnecting their battery again. If you choose to go that route with your own stuff whatever but don't offer it here as good advice.
