Improve turning radius
Old Nov 10, 2008 | 12:54 PM
jycsalas's Avatar
Default Improve turning radius
Hey guys,
I remember reading a post about the turning stops on the DII's and how you might improve your turning radius by removing them....I may be wrong..
Anyway... my question is if anything would get damaged if those stops are removed completely or if i can just grind them down to a safe length since I have 16 inch rims. I haven't been under my Disco in 2 weeks and I'm going crazy thinking about what it might affect...
THANKS
Old Nov 10, 2008 | 01:32 PM
hazletbassist89's Avatar
Default RE: Improve turning radius
http://www.roversnorth.com/store/p-1...covery-ii.aspx
I'm not positive about the turning stops, but this is one way to do it. Expensive, but maybe if you're handy with some metal you could make your own. Something I've considered doing for my DI as well...
Old Nov 10, 2008 | 02:48 PM
If you remove your turning stops, you will rub/wear the inside sidewall on your radius and you could bind up your wheel cause steering damage. Suggest you stay with narrow wheels and tires as the only way to cut the radius.
Old Nov 10, 2008 | 05:30 PM
sloppyjoe's Avatar
its a truck NOT a geo metro,,,
accept it
Old Nov 10, 2008 | 05:35 PM
snowdude's Avatar
AHAHAHA! isnt it fun getting used to the (forward, back up, forward, back up). there really no way to significantly improve radius, without ruining your trucks steering system.
Old Nov 10, 2008 | 05:43 PM
apcollin's Avatar
Disco's are pretty short by SUV standards... try a 3-pointer in a Suburban or Expedition
Old Nov 10, 2008 | 05:44 PM
Darover's Avatar
I run 265/70r16 General Grabber AT2 on Land Rover Range Rover 16X8.5 inch rims and I have a better turning radius than my wife's PT cruiser. In fact, on a normal big 2 way street, I can do a u-turn no problem. Guess those wheels really are responsible for that.
Old Nov 10, 2008 | 05:58 PM
sloppyjoe's Avatar
ORIGINAL: apcollin
my daily driver is a Ford F250 Super Duty with a extended cab and long bed. i drive that sucker in and out of seattle everyday to see customers and clients. that is a truck that is ZERO fun to 3 point in a hurry in seattle. the rover is a blessing in comparission.
Old Nov 10, 2008 | 06:03 PM
snowdude's Avatar
joe, i bet everyone in seattle loves your big gas guzzling f-250! muwhahaha pissing off the starbucks drinking librals.
Old Nov 10, 2008 | 06:06 PM
Disco2Guy's Avatar
It's also no Ford Explorer, which I could do a full 180* turn in front of my parents house. Not in the D2 however.
