Inconsistant Idle
Inconsistant Idle
I was sitting in my '03 Rover about 44K miles at a stoplight with the AC running and felt the engine being a little more active than normal.
My RPM's stay consistant but it almost feels like I'm running rich. It kind of sounds like my RPM's are jumping a bit but they don't. It's a bit louder with the AC's running but you can still hear it when the AC's off. You can also feel it slightly in the brake pedal.
It may be nothing but what should I look for? I checked all my levels and the only thing that is a bit low is my coolant.
Thanks in advance.
-Ugly
--If you give me something to check give me as much info as possible, I'm still getting used to crawling under and on my beast.
Thanks in advance.
-Ugly
RE: Inconsistant Idle
I put some Sea Foam in the gas tank today when I first noticed it. Should I run some thru the throttle body, via the vac tube?
One more thing, my Check Engine Light just came on. And I feel it more when it's in gear. If I'm in park and neutral you can hardly feel it. But once in drive or reverse or with the AC on it's more noticable.
Any prognosis?
-Ugly
Any prognosis?
-Ugly
