The infamous Heater Core
Old Nov 1, 2013 | 08:55 AM
drowssap's Avatar
nope all LR heater cores are a PIA, my RRC took 10 hours.
when you start with a right hand drive car and convert everything to left hand,
heater boxes and AC parts just get stuffed where they will fit.
Old Nov 3, 2013 | 10:59 PM
RSPTex's Avatar
Does anyone have a write up on how it is easiest to replace the heater core?
Old Nov 9, 2013 | 11:22 PM
tdefur's Avatar
So I got the heater core out...not too bad actually, 3 hours and that was because I stopped to take a drink after every bolt/screw was removed. I could talk someone thru it now Core was clogged with rust and sediment, took a full day to clean and power flush and now it actually flows. Took the core to a machine shop and had the o-ring fittings welded on and now I use 5/8" heater hose direct from the hard lines in the engine bay to the fittings on the core, gasket in firewall re-used of course. The book does not explain how to remove the OEM aluminum lines from the mounting bracket on the firewall, thus a grinder worked just fine. All back in, no leaks, and I even found enough change in the center console to pay for several beers. Thanks!
Old Nov 10, 2013 | 10:14 AM
oilspotLR's Avatar
So you removed the dash to do this?
Old Nov 10, 2013 | 04:10 PM
OffroadFrance's Avatar
Like Mike says, before you start ripping the dash out ensure the cooling system has been bled through properly and you haven't got an air lock in the cooling or heating system. Set all your heater controls to the hottest setting and go for a drive first to ensure all the water valves are open and allow to cool down and go through a thorough bleed of the system. There are many threads on coolant bleeding on here and other forums. It's simple to do but should be done properly.
Just for info I latterly found this on an Australian forum although it's a D1 it's virtually the same routine.
http://www.aulro.com/afvb/technical-...orkshop-5.html
Hope it helps.
Old Jul 11, 2014 | 03:25 PM
harleyguy's Avatar
does anyone have any advice on how to line up the clamps from the heater core to the tubes? I've been trying for over 3 hours and am getting no where fast.is there another way to clamp this ? it seems like a really hokey way of doing things.
Old Nov 21, 2019 | 09:16 AM
Broken08's Avatar
If you're still out there could you walk is through it?
Old Jun 11, 2020 | 02:34 PM
BurlDisco's Avatar
June 2020,
Heater core issue, of course it leaks. at the seals. at looking through the various forums ...tig weld the pipes right to the core. With the pipes all ready cut and using rubber hoses between the core and the fire wall this should work. hope!
Old Feb 1, 2021 | 10:11 AM
PAPIRRIN's Avatar
8th Gear
Hello Mike,
While doing some research I ran into this old post. Are you saying that a not properly bled system , can cause the heater core to leak? I have coolant all over my passenger floor. This happened right after I placed 2" spacers throughout. I had to remove the shock towers, and on the passenger side i had to move the coolant reservoir out of the way, but I did not disconnect it, but when I replaced everything back, I noticed the leak, and fumes from coolant inside the truck. I am not sure if this is pure coincidence that my heater core went bad, or that air got trapped in the system, there fore the leak. I hope you can answer me from this old post.
Thanks,
Mario
Old Feb 1, 2021 | 11:32 AM
TimInNova's Avatar
