inline mod help needed
Old Nov 1, 2020 | 05:38 AM
Davis31052's Avatar
Default inline mod help needed
Hello All,
Ok, there have been dozens of pics posted of top of different setups for the thermo mod. Each custom to its owner. The running info has been to use a "BMW" bottom hose after removing the OEM thermo. However, a clear view of this hose mounted hasn't been posted, to my recollection. I've seen pictures of the hose, and I guess I'm missing how it will interface, especially with the hose coming down from the fill tank. A good set of pictures and a part number would be greatly appreciated. I have accumulated all the parts I need for my swap over except the bottom hose.
TIA, eddie
Old Nov 1, 2020 | 05:56 AM
mollusc's Avatar
Write to Extinct. He has a full kit that he sells, with instructions, for a decent price. You don't need any different hoses.
Old Nov 1, 2020 | 06:16 AM
Davis31052's Avatar
Copy that, Thanks
Old Nov 1, 2020 | 06:49 AM
redwhitekat's Avatar
The bottom hose gets attached to the top hose of the thermostat, the thermostat is removed the hose that comes from the block gets cut back and thermostat installed modulating the flow to top of rad
Old Nov 1, 2020 | 07:12 AM
Bom2oo2's Avatar
You want to use “Gates 22073” for bottom hose it’s a direct fit not the BMW, but if you are going with the kit I guess he has all the correct parts lined up already.
Old Nov 1, 2020 | 11:18 AM
mollusc's Avatar
The kit is a thermostat and instructions. There's no need to get different hoses at all.
Old Nov 1, 2020 | 07:59 PM
Extinct's Avatar
Send me your email in a PM and I will send you the info. No new hoses needed. Only the thermostat kit, super easy to do. Uses factory hoses and clamps.
Old Nov 2, 2020 | 07:27 AM
jastutte's Avatar
^this.
about the easiest and most straight forward mod i have done on any vehicle.
archaeology_student
May 24, 2020 09:23 PM
cappedup
Apr 26, 2016 09:31 AM
dnbrown9
Dec 14, 2015 10:11 PM
Emperor_MA
Jun 18, 2013 07:55 PM
jstreet
Dec 16, 2006 07:44 PM
