Inline thermostat mod. Do it. Love it.
#21
I too am a big fan of this modification, having installed Extincts kit earlier this fall. Temps are upper 170-lower 180's. However now with the colder weather I am getting a p0126 code (insufficient coolant temperature) on my Ultragauge.. I haven't seen an actual check engine light code, but having to reset the Ultragauge everytime I start the truck is a bit inconvenient.
Perhaps I should switch to a 190 thermostat until spring?
#22
#23
This isn't just about the temperature, people. This is about component durability and system simplicity. The only noted drawback so far has been a very slight increase in the time it takes to bring the cabin heater up to full temperature.
#24
#25
@Jackspratt2 not significantly - that was the normal temp range for these engines for years until I believe 03 or 04 when LR went to a 190 shipped later revised to a 180 due to overheating issues. All the inline does is get rid of the oem style thermostat and go back to the style and general location the engine was designed for.
The Disco as delivered had a thermostat that opened at 179 and was fully open at 204, once we are in that range we are in the normal operating temp range of the engine. As well you can just put a "hotter" thermostat in if required.
The advantages far outweigh the disadvantages :
- Simpler coolant path
- Easy to change thermostat with little coolant loss
- Better thermostat location for engine cooling on the hot side rather than than cold side
#28
The only way the D2 will run rich is if the 02's are dead, and even then it would take a huge altitude change. Both my front 02s are dead on my 250k mile 00 and I got 17mpg on multiple 600 mile trips this summer. With dead 02's the ECU defaults to speed/tps programming that runs a bit to the lean side.
#29
In other words, a thermostat does not allow running cooler which is different than not allowing running hotter. You can still run as hot as you want by pulling a trailer, climbing, high ambient, poor radiator flow, poor air flow...
#30
