Insitu welding
Old Jun 2, 2015 | 05:04 PM
OffroadFrance's Avatar
Default Insitu welding
I am about to replace the underrun bar on my truck. It has rotted away and I'm replacing it with a 400mm galvanised square hollow section. I need to tack weld the end plates insitu then remove it and fully weld the joints. Please can anyone advise me what electrical/electronic precautions I need to take as I was intending disconnecting the battery and possibly unplugging the engine ECU this was mainly due to possible EMF created. Does anyone have experience of insitu welding on their truck and whether there any risks.
Old Jun 2, 2015 | 05:44 PM
antichrist's Avatar
Also, disconnect the alternator. Attach the weld ground to the piece you're welding and make sure you strike the arc on the piece the ground is attached to.
Grind the weld area to bare metal as well as the ground attachment point.
DO NOT breath the fumes (use a fan to blow them away from you).
Zinc fumes are very toxic.
Old Jun 2, 2015 | 06:05 PM
Thanks for the info antichrist it is much appreciated. I didn't think to even consider the alternator but obviously it has diodes embedded. Thanks also for the safety tips as I'm usually a bit of a 'chancer' on my own (hence all the scars). I'm good at handing out advice to others but often ignore safety precautions myself
Old Jun 2, 2015 | 11:24 PM
BusaRider's Avatar
Just make sure you have a really clean and good ground CLOSE to the repair. We can debate for years about disconnecting electronics. Disconnect if it makes you feel safe or warm and fuzzy inside. Good luck!
Old Jun 3, 2015 | 12:06 AM
cappedup's Avatar
As far as I know. Take the battery earth off. Ground the piece as close to the actual weld. Electric, path of least resistance etc. everything else doesn't feel a thing.
But, if it has a plug and your concerned and it's easy. Whip it off.
Old Jun 3, 2015 | 01:46 AM
Bom2oo2's Avatar
X2 on alternator disconnect, I have seen them go bad on many occasions & I have seen them survive in some cases, why take a chance!
Old Jun 3, 2015 | 05:15 AM
drowssap's Avatar
battery ground should do it, it does on every other vehicle
Old Jun 3, 2015 | 09:44 AM
cappedup's Avatar
Just re reading this. Yes. The biggest thing is the health risk from the galv. You can grind it off the bit that will take the heat, so it doesn't create fumes. But some will invariably still be produced. Also then the bit that you have ground will rust, so needs a coat of something.
You're only tacking it in place while under the vehicle. Earth off, really should be enough.
Old Jun 3, 2015 | 10:37 AM
antichrist's Avatar
It can be difficult to grind it off inside the tube. That's why I said use a fan, so the OP can be upwind of the weldment and the fumes.
Tacking it is the most risky time because there's no bond between the two pieces.
Should be is the key. But when doing what he's talking about the current can potentially take the long way round to the ground clamp if the arc is struck on the other piece (I've had it happen). That's the reason I said as close to the joint as possible and strike the arc on the piece the ground is attached to.
Old Jun 3, 2015 | 02:54 PM
Good advice guys I really appreciate your inputs.
I've ground a 1/4" mitre all round on the 40x40mm SHS tube but accessing the inside is a different and difficult game so I'll tack it up with a couple of 1/2" tacks one each side each end and do it in the open air with a fan blower across and away from me under the truck and ensure I strike the arc on the tube and not the end plate and then fully weld it out on a bench in the fresh air outside with the fan blowing across between me and the work piece, fortunately I have one of those full face solar activated mask thingies to direct the fan into. I will use some passivate and cold galvanising paint (galvafroid) when it's finished to avoid rust. These underrun protection bars have a nasty habit of rotting away with rust so I decided to fabricate this one as a 'heavy duty' galvanised replacement once and for all.
bosshogt
Aug 1, 2011 09:35 PM
devildog01
Mar 2, 2010 06:33 AM
03discoman
Jan 22, 2010 11:03 PM
NiteTrain
Off Topic
Aug 20, 2009 05:48 PM
jgbufton
Nov 17, 2007 10:04 AM
