Installed CDL in my 2003 Discovery
Old Mar 16, 2009 | 03:38 PM
jycsalas's Avatar
Default Installed CDL in my 2003 Discovery
For those of you with the 2003 Discovery...and want CDL. It has been done.
http://picasaweb.google.com/jycsalas/AddingCDL#
and then enable the diff lock light
http://picasaweb.google.com/jycsalas...DiffLockLight#
Now i can run with the big boys...
Old Mar 16, 2009 | 03:43 PM
discoxd's Avatar
man you are just makin all kinds of progress these days... i need to stop bein lazy and do something to one of my rovers...
Old Mar 16, 2009 | 03:49 PM
jycsalas's Avatar
haha yeah. I just wanted to bring my rig up to speed...the most important mod I personally could do was the cdl... later i'll do some more serious mods like off road tires...
Old Mar 16, 2009 | 07:46 PM
nynole's Avatar
Talking
Today must be my Birthday!
Old Mar 16, 2009 | 07:57 PM
nynole's Avatar
Did you have any issues with the new locking output housing? Same driveshaft (lenght)?. What was the green wire from the old non-locking housing? And did you have any concerns about the HDC (did you disable or just left it as is)? Sorry about the ?'s but I'm thinking about doing this to mine. Thanks!
Old Mar 16, 2009 | 11:25 PM
discoboy's Avatar
Man, that is a great install, I want this really bad, but so much work. Thanks for the pics.
Old Mar 17, 2009 | 07:35 AM
jycsalas's Avatar
Actually Saturday March 14th WAS my birthday. I'm 24 years old!
Old Mar 17, 2009 | 07:49 AM
jycsalas's Avatar
Everything matches and mates correctly. The green wire you see is the neutral switch. there are two neutral switches. one on the front of the output housing, and one at the top of the main casing. they detect whether or not you are in neutral at the t-case.
On a 03, the neutral interlock switch is at the hi/lo assembly it's self, NOT on the t-case. If the transmission isn't in neutral, the shifter WONT allow you to engage into hi/lo. in my situation right now, those functions are independent from engaging the diff-lock. i can just get under the truck and lock the nipple by hand meaning i don't need the t-case in N to lock it.
Regarding HDC/tc... from the research i have done, the 03's were designed to "ignore" the diff lock input signal at the SLABS ecu which allows me to retain HDC/TC/abs WITH diff lock engaged...
read here for some more info on diff lock affecting HDC/TC/ABS
http://www.discovery2.co.uk/diff_lock.html
Old Mar 20, 2009 | 01:01 PM
jycsalas's Avatar
If anyone wants the write-up i made for this, email me. (its a pdf)
jycsalas@gmail.com
Old Apr 13, 2009 | 11:30 AM
jycsalas's Avatar
HEY EVERYONE!!!
I keep getting many requests for the CDL write-up!!! Keep them coming!!
And for those of you who want to know what I did as a shifter...
http://picasaweb.google.com/jycsalas/AddingCDLShifter#
I will start a separate thread on this so please wait until it's up so we can keep comments specific to the shifter over there...thanks.
