Installing Hella's- which fuse
Old Oct 14, 2013 | 08:53 PM
coors's Avatar
You could always find a spare cruise control (on/off) switch wire the relay and lights to it. Then replace the cruise control switch-face to a blank one so it sits stealthily in the cluster. That's what I did.
Old Oct 15, 2013 | 08:15 AM
cosmiccharlie's Avatar
Or replace with a fog light face.
Agree with everything said, do not wire through your stock wiring. It's very easy to wire independently.
Old Oct 15, 2013 | 09:49 AM
dtm325's Avatar
I'm wiring everything independently- i just want to use the factory switch in the dash. I have an independent relay, separate grounds and direct power from the battery. The ONLY thing i want to use from the fuse box is the a trigger to turn the lights on/off from inside the cabin, using the factory button provided from the factory, inside the vehicle.
So i cannot use the factory switch, through the fuse box? The light turns on when i press it, so it has power going to it. IF the switch is momentary, it still sends a signal to the ecu to open/close the relay-It already interacts with the ECU. I'm not installing the switch, it was there from the factory, along with the relay.
Old Oct 15, 2013 | 10:36 AM
First, you need an on/off (cruise control switch). The factory switch will not work as it is a momentary switch.
Second, there is no reason to run your power wire through the factory fuse box. Use an aftermarket fuse block, or if you don't plan on adding any other accessories or lights, a simple inline fuse in your power wire.
Old Oct 15, 2013 | 03:18 PM
dtm325's Avatar
I have a fuse in my power line, the only reason i was tapping into the fuse box was so i could use the factory fog light switch- (just one wire)
Thanks for the help.
Old Dec 16, 2014 | 09:20 AM
dparham's Avatar
I am doing this too! Im heading to salvage yard they have couple discos out there!! WOOHOO! no different than working on mine! hahaha
mx468
Jan 24, 2015 12:17 AM
Blakesrover
Feb 21, 2013 01:43 AM
AK Rover
Mar 20, 2009 09:51 PM
duckprefect
Freelander
Mar 9, 2009 08:27 AM
yarddawg
Feb 10, 2008 10:32 PM
