? on installing HID kit to OEM Aux Light Switch
Old Oct 2, 2009 | 10:53 AM
RjBu's Avatar
Default ? on installing HID kit to OEM Aux Light Switch
Hey folks,
I am waiting to get a new set of NBB Alpha 225 HID's in and had a question for all of you. So i know how to build a basic wiring harness but dont know how to junction it into the OEM DII switch from Expedition Exchange??? i was looking at the RAVE for the factory installation instructions and noticed that they had a plastic clip going into the back of the switch? Where can i find one of those? Or is it possible to skip that piece and jack straight into the back of the switch? Also Factory has 4 wires going into the switch? I am guessing that i would only have 2? Any imput on configuration would be wildly helpful!
Old Oct 2, 2009 | 12:03 PM
gilder's Avatar
Install beneath the rear fog lamp switch. The panel blank should have a wiring harness end attached to it. Plug that in to your new switch. Now, under the front frame you should find the fog lamp wires - the passenger side will easy to see. Don't know for sure where the driver side is - may be behind the washer reservoir. Plug your new lights into these or splice them in. Then you will need to get a rover shop to activate the lights in the ECU for the switch to work.
Old Oct 2, 2009 | 12:22 PM
RjBu's Avatar
I was just going to wire the lights straight to the battery via a relay? Then splice the switch leads (red & black) into the "Blanks harness"/Aux switch harness? Will that work? I want them to work independently of the headlights/fogs... Do i still need to take it to the shop to have the ECU adjusted if i take this route? If i do it my way will the switch still light up as it should?
Old Oct 2, 2009 | 02:22 PM
RjBu's Avatar
Ok after extensive searching i am going to post a link to the method and parts sourcing for the way that i am going to do this (http://www.lrrforums.com/showthread.php?t=12375)
Old Oct 2, 2009 | 02:28 PM
hilltoppersx's Avatar
let me know how this works out for you. i bought that same switch from the dealer, but am yet to buy lights, have been busy fixing things instead.
az20115.0
LR4
Jun 30, 2014 02:27 PM
Bassmaster
Jan 6, 2014 09:24 PM
SD4x4
Audio/Visual Electronics
Dec 17, 2013 01:24 AM
scarlettwu
Off Topic
Mar 25, 2009 02:10 AM
