Installing Infinity Basslink powered sub to factory Alpine system
Old Jan 11, 2010 | 03:49 PM
Disco_Fever's Avatar
Default Installing Infinity Basslink powered sub to factory Alpine system
OK, so you see the title... I have decided against an aftermarket stereo for my truck. I don't want to spend the money for something high-end, and don't want to put in junk. How's that for a conundrum? LOL
I bought an Infinity Basslink 200w powered sub off of CL for $100, how do I hook it up? Keep it simple, a schematic would be great!
Also, for iPod/iPhone integration and to keep my CD changer, I'm going to use Roverville Radio to add an aux jack to the face of the factory head unit.
http://www.roverville.us/
So, anyone? Help with the hookup on the Infinity Basslink, please!
Thanks!
Old Jan 11, 2010 | 09:35 PM
Rover Chris's Avatar
should just be power, ground, and audio input. I am pretty sure on those you can even use audio sense and don't need a remote wire (it just turns on the amp when it senses an audio signal). As for the audio input I would go with high level (just tap into a speaker wire in the back) and you should be good to go. if you need a diagram for the sub you should be able to download one off infinity's website, but they are pretty basic powered subs.
Old Jan 11, 2010 | 11:24 PM
brianb883's Avatar
Since this sub you bought is powered, do not tap into the sub wires in the door, those wires are getting the full wattage output of the amp through them and will FRY your powered sub. You will need to find the wires inputting the signal into the amp, and connect to those, so that the built in amplifier in your infinity subwoofer takes the place of the stock amp. I think the amp is under the driver's seat, so you will need to run some wires depending on where you're planning on placing the sub.
Old Jan 13, 2010 | 07:05 PM
actually your basslink should have a high level input since it is designed to be added to a factory system. As long as you wire it correctly this will not cause any damage.
Old Jan 14, 2010 | 10:09 AM
I don't think it has a high-level input, but I bought a $25 line level converter so no biggie. My plan is to hook it up this weekend, I want it to be easily removable so that if I need all of the cargo area I can just unhook the sub and do what I need to do. I'm planning to leave the factory sub hooked up as well so that if/when I pull the Basslink I will still have the stock system properly functioning. Unless of course it sounds like garbage with the factory sub still hooked up, then I'll have to rethink that.
Old Jan 14, 2010 | 11:04 AM
DavidG's Avatar
Basslink does have high level inputs. I have one in my truck but I've also changed my head unit and am using the subwoofer outputs from that so I'm no help on specific wires. I had it fed by high level source in my last truck, worked great.
Old Jan 14, 2010 | 01:37 PM
Cool, then I may be getting my $25 back! LOL
Old Jan 10, 2011 | 05:47 AM
Mark_Bedell's Avatar
6th Gear
Default CISSP Training, Shon Harris Training, CISSP Study Materials, CISSP Classes
thanks guys lovely discussion great work.please continue
Security video course
Fuddy
Dec 21, 2014 09:41 PM
SpeedAgent
Audio/Visual Electronics
May 12, 2008 12:27 PM
bryan_2000hse
Feb 18, 2006 12:10 AM
FORDSTANGER
Aug 13, 2005 10:43 AM
