Intake plenum threading
Old Mar 8, 2024 | 07:53 AM
redrover75's Avatar
Default Intake plenum threading
Does anyone have a fix for this junction leaking? Aside from ordering a new plastic plug. Is there an upgrade? Or just put in an oem. It's the rigid line adjacent to the osv.
Smoke test showed a pretty good leak while chasing a p1415.
Old Mar 8, 2024 | 08:09 AM
whowa004's Avatar
plug is cheap and relatively simple to fix, there's a write up that makes is super simple on here somewhere.
could also always RTV it but that's not the right way to do it lol
Old Mar 8, 2024 | 09:39 AM
redrover75's Avatar
Default Fix
I saw that, was just wondering if there was something better than oem.
Old Mar 8, 2024 | 12:51 PM
andino's Avatar
The downside to replacing that fitting with something else is you'll need to adapt the line from the brake booster as well to fit the new fitting. I'd just replace with the OEM one as they last quite a while until the orings flatten enough to have issues. You can tap out the old fitting with some extensions and a 10mm socket through the throttle body butterfly
Old Mar 8, 2024 | 08:28 PM
Best4x4's Avatar
A Saab uses the same style fitting
Abigail Galloway
Aug 20, 2020 07:31 PM
robert.juric
Apr 21, 2017 08:15 AM
dougn
Apr 16, 2015 09:16 AM
vandev
Apr 24, 2010 01:43 PM
03DiscoSE
Apr 2, 2009 03:17 PM
