intake question
ok the line running off the brake booster to the intake, how important is the fitting? its completely out. can i just use some sealant to hold it in for now? im having to move in two days and i dont want to have to pay for a tow truck. i have to drive it 30 mi away. witch would save me 90 bucks. i ended up ordering the wrong one, also does anyone have the correct part number for it?
I've seen more glued in with silicone than I have seen with the port still intact. I think too many shops don't know how to disconnect the vacuum line and end up breaking the port. You'll probably be fine.
Intake Manifold Brake Servo Vacuum (Genuine Part # LZN100220L) - Land Rover hydraulics from Atlantic British
http://landrovermerriamparts.com/par...&siteid=215719
i took the port out. this is the one i bought. it doesnt fit to the vac line.
Land Rover Fitting PVC Pipe to Valve Cover Freelander V6 02 05 LZN100390L | eBay
