Integrated Relays - Description
Old Jan 7, 2023 | 10:17 AM
betzdII's Avatar
Default Integrated Relays - Description
2004 Land Rover Discovery II - this integrated Relay is clicking when shifter goes to Neutral.and puts truck in limp mode. Looked on the Rave manual and couldn't find a description of what each relay goes to. Any help would be appreciated. Its the TYCO relay I need help with. This is the cabin fuse box.
Bub
Old Jan 7, 2023 | 12:42 PM
XRAD's Avatar
I see the pry mark where someone tried to pry the realy out. It is soldered to the board. these relays are still available (cheap < 10$)...BUT, unless you have the ability to desolder from the board and not destroy the pin hole solder points, it is easier to get a used board off ebay....and this still may not be the issue. Just because it 'clicks' does not always mean that the relay is bad...
check all board traces while you have it out....
search ebay:
2003/04 LAND ROVER DISCOVERY 2 INTERIOR UNDER DASH FUSE BOX YQE000251 OEM 4.6L
Old Jan 7, 2023 | 01:35 PM
betzdII's Avatar
search ebay:
I was hoping to find out what this relay controls so I could trace wires that could be shorting out or something that could be causing it to click. Thanks
Mr. Tick
Aug 4, 2020 04:20 PM
lr4_2012
LR4
Jun 5, 2019 03:13 PM
xathor
Jul 28, 2017 07:40 PM
dobe1canobe
Jan 26, 2015 12:29 PM
kevinb91
Dec 7, 2011 09:34 PM
