Interior floor/floormat leak - AC?
Old Aug 12, 2015 | 09:27 PM
Atlrover89's Avatar
Default Interior floor/floormat leak - AC?
On the passenger side of my 01 Disco II the floor is getting soaked in front of the front and back seat. I have felt around all over the place, looked all over to see the source of the leak but I see nothing.
I searched on here to see if there were any related threads and didn't see any. If you know of any, send them my way please :]
There's been no rain here and the AC has been running both times but I can't pinpoint the source. Anyone had this issue?
Old Aug 12, 2015 | 09:30 PM
Joemamma1954's Avatar
This is very common on these vehicles.
It is your a/c vent clogged. You have to get under your vehicle, and there are two rubber tubes with pointed nipples. the nipples can be removed and cleaned. Be prepared for a flood of water to come out.
Old Aug 12, 2015 | 09:33 PM
They are right around where the cats are, coming out of the rise of the floorboard where transmission is.
Old Aug 12, 2015 | 09:36 PM
Charlie_V's Avatar
Mine clog up A LOT. Why are those nipples not more open? Any harm to opening them more?
Old Aug 12, 2015 | 09:37 PM
cappedup's Avatar
These were trickier to find than I thought they would be. Higher up than I imagined.
Old Aug 12, 2015 | 09:40 PM
Dave03S's Avatar
Personally, I give my nipples a squeeze with every oil change/propshaft greasing.
Old Aug 12, 2015 | 09:41 PM
I removed mine and going to stick a tube and route to each side a bit. Right now they are open.
Old Aug 12, 2015 | 09:46 PM
Charlie_V's Avatar
Do the nipples pull off the end? It would be nice to route them away from the cat and driveshaft.
To the OP, I usually find a wire hanger and make something to piddle with them. It always gets me filthy.
Old Aug 12, 2015 | 09:49 PM
The nipples pull out of the end, they are installed in the tube, not on the tube. FYI
Old Aug 12, 2015 | 09:50 PM
Dave03S's Avatar
What he is saying is that you can clear them by finding the two tubes on the underside of the tranny tunnel and then poking a thin stiff object (like a straightened shirt hanger) up through the opening in the nipple. That will release the backed up liquid which is the condensed water from the A/C system. Some people use compressed air to blow out the blockages but it is a low pressure system so high pressure could cause damage.
This should be a part of your regular maintenance routine.
If you live in a hot weather area you can open your windows and let the carpets dry, otherwise remove them and dry them and the floor pan to prevent mold or rust.
