Intermediate Steering Shaft
Old Jun 12, 2017 | 03:35 PM
CollieRover's Avatar
Default Intermediate Steering Shaft
I am replacing my intermediate steering shaft, and the U Joint at the Steering box is rusted on. it isn't giving me enough play to remove.
Soaked it in Seafoam Deep Creep and smacked the top of it with a hammer, and will try to pry it off again.
If that doesn't work I am reticent to put heat on it. I don't want to damage the steering box or engine mount which is close. I would be using propane.
What do you guys think?
Old Jun 12, 2017 | 05:44 PM
BackInA88's Avatar
Did you completely remove the bolt on the u-joint side mounting to the steering box input?
I don't believe it will slide off the shaft without removing it completely?
Then pound a screwdriver in the split that the bolt closes up when tightening.
Old Jun 12, 2017 | 05:54 PM
OffroadFrance's Avatar
X1 ......... RAVE page 57-32 tells all.
Old Jun 12, 2017 | 07:29 PM
I followed the Rave instruction, all three bolts are out and I have wedged a screwdriver in the gaps to open them. The union at the steering jack is free, but the u joint at the shaft is rusted solid to it. It won't slide up, and there is not enough play to allow it to come off. About a half inch short.
i soaked it in Deep Creep and pounded it a bit with a hammer. Not a ton of room to operate, and I don't want to damage anything.
Old Jun 13, 2017 | 12:02 PM
I was able to get it moving using a17mm and 19mm wrench behind a crowbar. That wedged it off. I don't think I banged anything up while doing, but it is a tight squeeze.
the i joint at the steering wheel end was a bear too. Used every wedge tool I could find to really separate the i joint, ended up being able to wedge the crowbar behind it and the **** in front of it. Used a paint stick to soften the end of the crowbar so I did not scratch up the firewall. That method was able to get pressure on the u joint and it popped off.
i am going to keep the u joint and try to rebuild it. You never know!
darkaegis
Sep 5, 2016 09:02 PM
cobra29
Aug 4, 2016 01:35 AM
grussell
May 12, 2009 11:51 AM
cst756
Jun 25, 2008 05:39 PM
Evian
Aug 31, 2005 08:04 PM
