Intermittent start, turn key = Click
OffroadFrance called it. I checked all connections repeatedly, and load tested battery. 12 volts at starter, but it was stuck in engaged position. It was a rebuild and in this case I had the shop do the replacment. Had it towed there by AAA and they replaced free of charge under warranty. Let's hope this one lasts more than a week! Why is it such a crapshoot to get rebuilt starter? Thanks all!
"Let's hope this one lasts more than a week! Why is it such a crapshoot to get rebuilt starter?" it's a sad case of some you win others you lose, generally it's a case of rebuild quality and they often skimp on the expensive or obvious parts like solenoids, bearings etc. The trouble with starter motors is they work hard but only for a few seconds usually and they flunk without warning.
spoke too soon
One start with the new starter and it failed again. Another tow to the garage (third time). Same circumstance. They indicate the "starter is staying engaged."
This does not really make sense to me, as staying engaged I picture it grinding against the flywheel. But those are their words. Either way, they are able to move the motor back into place, turn key and get a few starts, then it's back to the click.
They are proposing that we go to an OEM starter, which strikes me as an expensive and fruitless plan. Does anyone know how many teeth should be a D2 starter - possible they are providing the wrong part? Any ideas?
Thanks, all!
Thanks, all!
I don't know the tooth count.
But, if the starter gear is wrong, then it should bind and/or grind, and the starter and ring gear should show visibly noticeable wear or damage.
I would not think that is the problem.
Could you have gotten bad aftermarket starters? Definately.
Is that the problem? So far it's anyone's guess.
Sorry I don't have more info for you.
jeffery212 (04-13-2018)
Thanks, all!
Thanks, all!
STILL struggling with this. My local shop has basically told me, take it away. He's not inept - has been doing this 30 years, although he admits he does not see many rovers. I keep telling him, there is nothing special to the starter system here.
He says plenty of amps, and the small 12 volt line responds find to the ignition.
He is having same symptoms with two starters. Car will start several times, then suddenly he gets just a click, and upon checking the starter motor is stuck engaged in the flex plate.
I've read about shimming to fine tune the position of the starter. Could that help with sticking?
Or weak bendix spring - but that seems odd for intermittent issue?
Maybe run a second ground?
Anyone familiar with the Atlantic British starters?
Thanks!!
Thanks!!
Thanks!!
Thanks!!
Call AB and see what their technician has to say. You'd be real unlucky with this many bad starters.
You may check the condition of the Fuse Boxes. When have my BCU issue I read a few people that experienced those rotting and causing starting issues.
I think the minimum time for newbies is at least 6 months.
Just kidding.
Just kidding.
