It's windy in my Disco II
Has anyone had a problem with draftiness inside your truck? The driver's side window vibrates when I'm on the freeway and there's a definite draft seaping in on that side. The window doesn't vibrate to the point of rattling, but the movement is visible. When I was stopped at a traffic light today, the wind was seaping into the vehicle. I could feel the air coming in from the top and sides of the window.
Any ideas on how to correct this?
Mike
Mike
RE: It's windy in my Disco II
Quite common on the defenders.. My entire top of the door moves and you can see daylight through the gap.. but then again, my doors are in need of replacement..
If the draught is coming around the glass area, check to make sure the glass is rising fully into place, and is not been prevented from entering the slot by a stone and such like.
If it is entering the slot okay, check how tight the rubber seal is around the glass, if it is worn and loose, then the only remedy is to replace the seal.
If the draught is actually coming from between the edge of the door and the body work, then you can make adjustment to the door seating on the hinges to provide a tighter fit. It would also be worth checking the conidition of the rubber seals in this area and replace if worn.
Mike:
I have a 96 disco and I have a similar wind problem. I find it is especially bad on the drivers side when I have a crosswind moving right to left across the car. It sounds like I'm driving through a tornado. There have been times where the driver's side window has been moving so much that I've driven for stretches with one hand on the window, as crazy as that sounds. But every time the dealer looks at it, he says its fine and he can't reproduce the noise. I've taken the same steps as you have and even looked at the door seating, which seems ok. It may just be something you have to live with if your in a windy place.
My only remedy has been to turn the radio up loud enough so that I can't hear it...
--Whodey
--Whodey
Mike,
There is A complicated way of adjusting the window run channels that involves removing the door panel. Frankly, it is A pain and doesn't usually work any way. The real world fix may seem scary at first but trust me it works. 1. Put window down. 2. open door and place A dollar bill between the door and the door seal. 3. Close door so that Dollar is trapped between door and seal. If you can pull out the bill easily it needs to be adjusted. Also you can see how much the upper part of the door frame is compressing the seal with the window down. To adjust, put window down, open door, put your knee on the top of the door panel and pull the upper frame to you. Adjusting it in slightly. Keep adjusting until you can see the seal is getting compressed significantly and/or the bill has some drag on it.
The other adj is the door striker. It requires A Torx bit to move the pedestal in the door jam. But the first adj should do the trick. Let us know how you make out.
Bait
Bait
