Jump seats
I saw it in this forums that it is possible. BUT it was also stated that somehow risky because if you get into an accident and sombody got injured in the back, it will be your fault. You vin i guess states that its a 5 passenger not 7. I wanted to try as well coz i got all the panel etc to do it. But, i could be mistaken. Search it here again.
Gerry
Gerry
You know what is more risky than converting your SE into an SE7? Being involved in an accident (other persons fault) and having their Insurance company instantly try to total out your LR because it's 13+ years old, and in their minds a POS that just needs to be sent to a Junk Yard.....
I had that situation so many times with a LR and Insurance companies it's sickening!! First they'll say oh well the VIN shows it to be an SD when it clearly has SE or HSE on the side, sun roofs, yada yada yada just to get the lowest amount possible to you. Then they'll act like maybe because it was 13+ years old it wasn't a safe vehicle and that could have contributed to the accident (even though you stopped and were rear ended, or they slammed into you....).
I call BS on being sued or at fault for making a 5 passenger into a 7 passenger. If you take every single part from the SD7/SE7/LE7/HSE7 and it's 100% all OEM how do those idiots know it wasn't a dealer installed upgrade after it was purchased???
My 98 D1 50th Anniversary LSE has them in the back, and they're not on the window sticker because they were added after the vehicle was sold. I knew this because I bought it from the original owner who said they ordered it, and then found out you could get jump seats, so after it arrived the local dealership installed them. Just like how 99% of all LR's appear to have leather seats, but sometimes you'll find that the cloth seats were swapped out at the dealership after purchase (can usually spot em on a D2 when the door trim is cloth vs suede).
In this world people will sue or fight over the smallest thing. IMHO it's your LR and you should be able to do whatever you want with it. Heck get all the parts from the donor vehicle and have em installed at a local LR dealership/Independent LR Shop and in the event something happens whip that receipt out and say these were installed at a LR Shop.
Or go buy an SD7/SE7/LE7/HSE7.
When I did my 7 seat conversion, there were a few small parts I did not think about and had to run back to the junkyard to pull from the junked SE7:
Lower anchor brackets for seat belts
Bolts for seats
Lower latch that the seats "clip" into on the floor
I did not replace the black metal framework behind the lower panels, the factory ones use a stud and a bolt, but the 5 pax ones have holes there and I ended up just using 4 bolts on each seat. Did mine recently, if you do yours and need help pm me.
Bolts for seats
By not calling the police you avoided them reporting your Disco was in an accident which would show up on a CarFax to any potential buyer down the road. You probably saved yourself some grief, especially since the hit was not all that bad. I say you came out ahead.
