Just bought our first DISCO... Now What?!
Long time fan of Land Rover rigs... FINALLY we found one!
So we finally found a really nice White 2002 LR Discovery 2 SE with only 57k on it! We have been looking forever, not in a hurry... and BAM! This one hit craigslist! We snagged it.
I plan on taking it with the family to West Yellowstone Park on our summer
vacation road trip. We live in Portland, OR so it will be about 12-15 hours drive there, depending on how many stops we make along the way. (got 2 boys, 4 and 6 yr olds)
Anyways... this rig looks and drives like new. I plan on taking it in to Columbia Rovers for its 60K service. (it has 57k on it now) As far as I can tell, it seems like the previous owners took care of it. It is totally stock. No mods.
I have only been a member here for a week, and have been trying to keep up on Disco Mikes advice (thank you in advance Disco Mike) on suggestions and tips for us first timers.
Your advice and suggestions is appreciated everybody!
Thanks!
-JKPinPDX
Thanks!
-JKPinPDX
Welcome. First order of business is having CR inspect the front driveshaft. These come stock without enough grease fittings. When they vibrate, chirp, and snap with almost no warning, they punch a hole in the transmision case. New transmissions can run $7000 at the dealer. DIY rebuild of the shaft is written up in our tech section, under $100 or so. Would advise reading through those tech articles. Download the RAVE service and owner's manuals in link below. Very popular oil is Shell Rotella 15W40, please consider an Ultra Gauge as an addition that reads and displays what you want from the engine computer, like coolant temp (the factory gauge is an idiot light with a pointer); it also reads and resets engine codes. See UltraGauge Automotive Information Center and OBDII Scan Tool. For the trip, suggest an inverter to charge small electronics, and a plug strip so you can run multiple things at one time. Of course, hope they'll see enough out the window to ignore the electronic toys, but......
Lol...
Anyway, start studying up, It's going to be a $$$$$ Ride....
Chris
on
First, don't take it to a shop to have the 60K done, they will only do part of what is needed and charge you a fortune for it leaving you with many items still needing attention.
If you are even slightly mechanical then go read my major service list at the top of this section and "YOU" do it all, with a little help from us, that way it will all be done right, you will learn what makes your truck tick and it will cost your hundreds less.
Read my list and then lets talk, also notice, you must rebuild or replace the front drive shaft prior to anything else. If it has not been done when it brakes, and lots of them do, it will take your tranny with it.
Thanks everyone for the advice, will do as much of it as I can.
Anything else I should order???? We bought this as a stone cold stock rig from a one owner that didn't do much to it.
...while Im at it, I should order all the parts and have it all done at once, and do some of the upgrades/maintenance myself. I have a limited schedule due to my work (I travel heavily for a living) So thanks in advance for the suggestions all!
For the mileage on yours I don't think I would order a complete front driveshaft. I would save the $450 and have yours rebuilt. From what I can tell just having the u-joints replaced with some good greaseable joints and then grease them every oil change and you will have no problems.
Then with the $450 order a OME 2" lift kit and a set of 33" BFG's.
Replacement driveshaft, $307 shipped. I know a few folks locally using them with good results.
Replacement drive shaft
