Just got my new rear ladder from AB.. WTF!!
Old Dec 25, 2010 | 05:43 PM
silvertank's Avatar
Default Just got my new rear ladder from AB.. WTF!!
Wife got me my roof rack ladder from Atlantic British..what the he'll is up with the Rivnuts. Are you telling me I have to go spend more money just for a simple 4 bolt install!?!? I've read sheet metal screws, but I'm not a hack, and like to install parts as intended.. Any advice Ladies and Gents?
Merry Christmas to you guys.. Thanks for all the help, support, guidance and fellowship...
Old Dec 25, 2010 | 05:56 PM
Camdisco24's Avatar
What's the problem with them?
I got mine from AB a couple year ago and installed it fine with what came in the box...
Old Dec 25, 2010 | 07:28 PM
hilltoppersx's Avatar
i think he doesnt have a pop rivet gun or something? is that the problem?
Old Dec 25, 2010 | 07:43 PM
Rover_Hokie's Avatar
I have never used rivet nuts, can you install them with a standard pop-rivet gun?
Old Dec 25, 2010 | 07:58 PM
Looks like you need a rivet nut tool or a work around.
http://bbs.homeshopmachinist.net/showthread.php?t=31855
http://mdmetric.com/tubtara/852tool.htm
Old Dec 25, 2010 | 08:17 PM
NiteTrain's Avatar
yeah, they are a PITA if you don't have a rivnut tool...pop rivet tool will not work
Old Dec 27, 2010 | 12:11 PM
dcarr1971's Avatar
I couldn't even find a tool with the right thread for the nuts that came with my ladder, so I just got a cheap (<$20) Rivnut tool at Harbor Freight and used the rivnuts that it came with...
Old Dec 27, 2010 | 03:28 PM
lipadj46's Avatar
And he's buying a stairway to heaven....
This will do it no?
http://www.harborfreight.com/3-in-1-...kit-94100.html
Old Dec 27, 2010 | 03:50 PM
dcarr1971's Avatar
This will do it no?
Close...the one I used was actually http://www.harborfreight.com/45-piec...-kit-1210.html
It comes with the rivnuts...I just took it over to Home Depot and got the right screws and I was good to go.
Old Dec 27, 2010 | 05:41 PM
antichrist's Avatar
Drill the hole
Get a hardened bolt to fit the rivnut.
Get a hex nut just enough larger than the bolt that the bolt will slide through.
Get a star washer same size as the nut
Insert the rivnut in the hole, slide the nut on to bolt, slide the star washer on to the bolt, screw the bolt in to the rivnut. Hold the hex nut with a wrench and screw in the bolt with another wrench. That will expand the rivnut in place.
