just replaced spark plugs....now I'm having issues.
Well before I ordered I used the promo code "BIMMERFORUM-10". I found it on a BMW forum, and it worked!!! even on the magnecor wires. I just used it today, I'm sure it will work for anyone else. The promo code I gave earlier was what I received once the order was placed. Also, you can check out any code by putting something in your shopping cart, and going to check out, free to check.
if the light isnt flashing, then its probably not the wires causing your issue, it takes a pretty good misfire to do what youre saying... check and make sure that you didnt leave any connectors unpluged, mafs, throttle pot, and make sure all your hoses are still tight. and the wire size doesnt all too much matter, you can use the stock ones with any plugs, as long as the plugs are the correct type, but the coil puts out what the coil puts out, different plug dont make more voltage through the wire
rechecked all the connection and started her up, I was watching the engine, and I could see a spark going off fairly consistently behind one of the wires. It was secure, but I no I shouldn't actually be seeing a spark?........I didn't see it on any of the other 7 wires/plugs. the spark plug is brand new!, any thoughts?
