Key Won't Move..
Hey all,
Just reaching out to see who else has had this issue/solved it. Everything seems fine with the Rover apart from the fact that I can't turn the key once in the ignition. I can turn the wheel back and forth 1/16th/ish rotation but the steering column lock seems stuck and the key won't turn. Any suggestions will help!
Thanks,
Zack
Thanks,
Zack
I have this issue every time I go to start my Rover. I had LR Stealership cut and program me a second key after I purchased the Rover. Long story short, the tumblers were so warn a fresh cut key was to much for the old out of spec tumblers. So, I have to insert the key fully, then back it out to that very temperamental "sweet spot"... chicka zroom!!
No one but me can start it. It's a gem when leaving it with the valet. No worries, pal. I got this one
![Smile](https://landroverforums.com/forum/images/smilies/H5uKDcM.png)
