Keys
I have a 96 D1 that I bought used about 1.5 months ago. It only came with one key, which is a desaster waiting to happen. Does anyone know if its possible to go to Walmart or to a locksmith and have a key made? Is there a chip inside? Is this a dealer only thing?
Thanks
Andy
Thanks
Andy
Are you talking about make a regular blank key or a key for a remote?
As old as you one key is, it is pretty warn out and not good to make a copy from. Go to a local dealer and ask them to pull up a key code number so you can then go to a lock smith and make an exact copy.
I had the same thing happen. Took it to Home Depot AFTER I had to purchase a blank key for a D1 off the internet and they were able to copy it. Assuming you have power locks, you'll want to also purchase a remote and have Land Rover set it for you.
I would NOT trust Home Depot (or any otherplace that uses a key machine with cassettes)-just ask-to make a key. Thecassettes that they use are specific to the key blanks that they provide.This does not apply to the newer machines without cassettes. If you did get a key copied from the machine with cassettes, you are really lucky, and it shouldn't have happened. I used to make keys at the HD, so you can take my advise or leave it, but the last time I checked blank key fobs are not that cheap for Land Rovers. Use a locksmith.
ORIGINAL: Newbie
OK, I will head to a locksmith then!
Thanks!
Andy
Thanks!
Andy
Do it right and save your self some grief.
