Knock
Old May 26, 2011 | 07:28 AM
RoverIT's Avatar
4th Gear
Default Knock
Ok here goes.
I have a Disco II with a knock (not a tick).
Symptoms:
-owned the Rover for 20k miles, just started having issue
-starts after engine warms up
-under no load it gets worse when I rev engine
-while braking, in drive, and reving (adding load) completely goes away
Whats causing it?
Using 15w40 oil (as per landroversonly.com advice).
Last oil change was 300 miles ago (no metal flakes).
thanks all
Old May 26, 2011 | 07:32 AM
sloan74's Avatar
You got a camera that can record and upload video (w/sound) to youtube or something?
Old May 26, 2011 | 07:36 AM
kenk's Avatar
Definitly doesn't sound like rod knock, or it would get MUCH worse under load and/or rpm increase.
I would say either something is loose and moving around or you got a bad catalytic converter.
Old May 26, 2011 | 07:43 AM
vandev's Avatar
Default check exhaust
i had a simular knock and it turned out to be my drivers side cat knocking on the side of the frame.. It is close anyway and needed to have a guy at the muffler shop heat up and pry over. Was fixed..
Chris
Old May 26, 2011 | 08:28 AM
RoverIT's Avatar
4th Gear
Chris
thanks, I'll take a look down under after work today. I was hoping/thinking is wasn't a Rod noise. My check engine light just came on and I'd bet its one of the o2 sensors before the CAT. Had an issue with is running rich and carbonizing a plug set just before last oil change too.
Old May 26, 2011 | 09:25 AM
Originally Posted by RoverIT
Ok here goes.
Symptoms:
Whats causing it?
thanks all
Stop driving it. How mechanical are you.
The longer it knocks, the more it will cost to repair.
Old May 26, 2011 | 11:20 AM
RoverIT's Avatar
4th Gear
Been sitting since the day it started knocking (no road time on knock). I have other cars. I am fair at most DIY as long as its in the RAVE pdf
Old May 26, 2011 | 07:25 PM
Bad cats.
Old May 26, 2011 | 07:42 PM
jafir's Avatar
Originally Posted by Spike555
Bad cats.
Saying that doesn't work as well as it does with dogs. Cats just don't care.
Old May 26, 2011 | 08:33 PM
Laugh out loud!
