Land Rover Discover Manual discrepancy
Old Apr 16, 2014 | 05:07 PM
ivanwood's Avatar
Default Land Rover Discover Manual discrepancy
I am in the process of re-building a 2003 Disco 2 4.6 L engine that lost coolant due to an expansion tank failure, so decided to check out the bottom end as well. I managed to get hold of an on-line LR Discovery manual and when checking the crankshaft con-rod diameter it appeared to be .015" under size based on the 2.2 to 2.22in given in the manual; however I fortunately rechecked it using my vernier and noticed the metric scale was reading 55.5mm the same as in the manual. I did a conversion using my phone and found 55.5mm is 2.185in., so the conversion in the LR manual is wrong. Has anyone else found other mistakes in the manual that could be costly? I assume since the LR is European that the metric measurement is correct.
Thanks
IW
Old Apr 16, 2014 | 05:25 PM
ralphobell's Avatar
Which manual? Link?
primussucks's Avatar
Good point... when I rebuild, I will stick with metric values... Sometimes (depending on how many beers) conversions can get screwed up. Nice find.
Old Apr 16, 2014 | 05:33 PM
dusty1's Avatar
I have found some torque specs differ from the torque specs list page to the repair pages in rave. and the box of bolts with threads from the block, still attached, says i, apparently, need to pay attention to those torque settings. not to mention the assortment of taps welded into sockets. slowly, I am converting my truck to sae.
Old Apr 18, 2014 | 07:45 AM
ivanwood's Avatar
Default Disco II Manual
It is one I downloaded from a link on one of the Forums and it had the Land Rover logo. Title page was:
Discovery Series II
WORKSHOP MANUAL - 1999MY ON
Sbonomo
Sep 25, 2012 01:39 PM
Rover Nick
Apr 19, 2011 03:39 PM
joatman
Aug 19, 2010 07:18 PM
Classklown90
Oct 9, 2009 11:42 PM
