Land Rover Discovery II Hawkeye Bearmach Diagnostic Tool
Old Mar 18, 2022 | 01:07 AM
disco524's Avatar
Default Land Rover Discovery II Hawkeye Bearmach Diagnostic Tool
I have had it on my toolbox for the past couple of years as I've owned 2 LR Disco II that had been sold since. Some greyish discoloration on ABS plastic, no cracks. **Firmware last updated few years ago to program ECU, Key Fobs in addition to original basic settings (read more below). Programmed for Disco II currently. This unit allows you to buy codes for other LR models.
Listed at ebay
https://www.ebay.com/itm/325088234816
Old Mar 18, 2022 | 09:45 AM
zacharyz28's Avatar
Does it read ABS codes?
Old Mar 18, 2022 | 09:56 AM
mollusc's Avatar
It does. The Hawkeye is a fantastic piece of equipment. Not quite as good as a Nanocom, but also much cheaper.
Old Mar 19, 2022 | 07:31 AM
JUKE179r's Avatar
Please keep in mind, Bearmach stopped support for the Hawkeye years ago so no more software/firmware updates:
https://www.bearmach.com/hawkeye-total
If you got an older LR you’ll be good using it:
DEFENDER (Includes Puma)
FREELANDER 1
FREELANDER 2
DISCOVERY 1
DISCOVERY 2
DISCOVERY 3
DISCOVERY 4
RANGE ROVER CLASSIC
RANGE ROVER (P38a)
RANGE ROVER (L322)
RANGE ROVER (L405)
RANGE ROVER SPORT (L494)
RANGE ROVER EVOQUE
Old Mar 19, 2022 | 08:54 AM
brivalen's Avatar
WIll this allow you to turn on DRL and change lock system to 1 button global unlock?
Old Mar 19, 2022 | 02:16 PM
disco524's Avatar
Yes, it also resets them. In addition, you can power bleed ABS pump. I believe the software update I have may have been the latest as it is enabled to program key fobs, ECU and more.
Old Aug 16, 2022 | 04:19 PM
meelash's Avatar
8th Gear
Listed at ebay
Any chance you still have this?
Old Aug 16, 2022 | 04:24 PM
brivalen's Avatar
How'd you get a software update? Is that something you didn't yourself?
Jaylong55
Jul 11, 2023 12:01 PM
Erica Nichols
Mar 17, 2020 09:12 AM
Corpraider
LR4
Oct 14, 2016 12:31 AM
Enrique5
Jun 13, 2014 03:43 PM
