land rover part?
well I got a used one from someone parting out a disco cause I have a generic one lr says they can't "read". I put it in and It idles better but still throws the code. I don't know if the used one I have is "genuine" so I don't want to go back up to the dealership and have them tell me the same thing as last time. Is there any other issues that are known to cause the stepper motor code? My haynes manual says that a bad speed sensor can cause bad idleing, I think that may be going bad as I found out a couple weeks ago my speedo is off and I have had 2 instances where my truck stumbled like it was running out of gas.
yea thats about the same as mine.
the reason I wanted to see was because the one I had the dealer couldn't read, I got it from advance auto it was supposed to be interchangeable according to the forum. I can't find anything wrong with the truck (that I think would be related) I runs ok in gear, a little high idle maybe. In neutral it pulses like it revs too low and over compensates revs back up. My understanding is when you replace the stepper sometimes you have to calibrate the computer and to do that I have to have a working stepper that the computer can read.
christina423
05-21-2015 04:41 PM
Landys4ever
08-10-2009 01:06 PM
