Leaking t-case bolt
Old Sep 26, 2013 | 12:15 AM
bballjames's Avatar
Default Leaking t-case bolt
Hey guys,
I resealed my transfer case last weekend and all went well. However, now one of the bolts is leaking. About a nickel size overnight.
How should I stop the leak? Teflon tape?
I resealed the plate with high temp RTV and have no other leaks anywhere.
Old Sep 26, 2013 | 07:57 AM
drowssap's Avatar
you could try Teflon, but that will only help if the hole in question goes thru the case and is not just tapped into the case.
Old Sep 26, 2013 | 10:15 AM
bballjames's Avatar
It is the bolt that is closest to the front on the passenger side. The corner bolt right next to the drain plug.
Old Sep 26, 2013 | 01:55 PM
nychaze's Avatar
Did you rtv the bolt threads? The bolts threads will leak since the bolts go all the way into the case.
Old Sep 27, 2013 | 06:49 AM
drowssap's Avatar
there your answer the bolt goes thru the case, so Teflon or RTV. I'm a big believer in RTV
rally1
Feb 22, 2022 06:22 AM
Nkhooter
Jul 2, 2013 06:28 AM
focusontheworld
Oct 21, 2012 01:00 AM
br3nt
Jan 24, 2007 09:26 AM
jcostello
Nov 2, 2006 10:28 PM
