Leave crankshaft position sensor out of its bracket?
Old 02-18-2022 | 04:27 PM
Brandon318's Avatar
Default Leave crankshaft position sensor out of its bracket?
Putting everything back together after a head gasket replacement and was wondering if there’s any risk to the sensor if the connector is left out of its bracket. I feel like that’s the hardest part about replacing it, so what if it’s just left out?
Old 02-18-2022 | 04:39 PM
zski128's Avatar
I left mine off for a couple of reasons, hard to get to if you need to replace and if you end up with a bad enough valve cover leak it can fill that connector with engine oil.
Old 02-18-2022 | 05:45 PM
Extinct's Avatar
Leave it out.
Old 02-18-2022 | 06:07 PM
mln01's Avatar
Agreed. Same for the O2 sensor connectors. Leave them off the little brackets but zip tie or twist tie the cables somewhere to ensure the wires can't touch the exhaust manifold.
Jar9148red
09-02-2021 10:34 PM
hrhoward
09-17-2019 01:39 PM
ukwildcats
10-16-2015 02:16 PM
kmyer74
05-29-2011 10:20 AM
smi8387
02-07-2006 01:15 PM
Quick Reply: Leave crankshaft position sensor out of its bracket?
