LED Bulbs for '04, Hyperflash? LED Relay?
Old Jan 15, 2022 | 08:00 AM
SWM's Avatar
SWM
Default LED Bulbs for '04, Hyperflash? LED Relay?
I have a few bulbs to replace on my new '04 D2 so I was thinking about upgrading the exteriors to all LED; turn signal, brake light, side repeater, etc, etc.
Without adding load resistors I haven't seen an LED relay available at the usual places. I understand it is controlled by the "brain" not a relay? What can I expect for hyper-flash or how are others correcting?
Old Jan 15, 2022 | 11:23 AM
Sean Maginness's Avatar
I have an 03 and mostly LED bulbs in it. I went with a resistor to retain regular flash rate.
Cruise control might not work when you change the brake bulbs. The system will no longer see its expected load.
I had a really weird failure in a LED brake bulb which would cause interior lights and other exterior lights to come on. New bulb sorted that.
And, I found a prior change to the third brake light wiring was causing issues with a LED replacement. Sorted that too.
Overall I really like the LED marker, indicator, brake, back up, and rear fog lights with LEDs.
Old Jan 15, 2022 | 04:07 PM
Discorama's Avatar
You need the dummy load resistors for the flashers. There is an electronic circuit inside the fuse assembly (cabin/drivers drivers side) and no option for a different relay.
Old Jan 15, 2022 | 08:50 PM
RA122125's Avatar
Banned
I went with these, no need for anything else, work great, bright as heck...https://www.ebay.com/itm/17413864628...53.m2749.l2649
discoinfernoOSV
Nov 28, 2021 11:41 AM
Art H
Aug 17, 2020 03:48 AM
aemnky606
Feb 25, 2020 08:37 PM
emerica243
Jan 30, 2019 06:02 PM
satxpipe
Oct 20, 2017 02:07 PM
