LED H7 headlight bulbs/lamps
Old Jan 28, 2015 | 04:45 AM
OffroadFrance's Avatar
Default LED H7 headlight bulbs/lamps
I have purchased some replacement headlamp H7 lamps for the D2 facelift. I'm hoping they cut down some of the unnecessary heat on the polycarbonate lens and also give a good light spectrum. I'll post how they perform after I've fitted them and they have been in place for a week or two. They also consume less power but not much as they are 50 watts each vs 55 watts standard lamps.
Old Jan 28, 2015 | 08:17 AM
Kinda curious to see how this sorts out. I've been considering some of the kits I've seen for the conversion.
Is that 50 watts the equivalent light output or the actual draw. Most of the kits I've seen have had 55 watt output but a much lower actual draw 20-25 watts?
Old Jan 28, 2015 | 10:42 AM
Racer X's Avatar
They're probably a 50w equivalent.
That said, I've seen some great examples for single filament replacement options, but the alignment on the dual filament modules just isn't all of the way there yet.
Old Jan 28, 2015 | 11:13 AM
I have had no luck with the dual filament set ups on HID so I would assume the LED is the same. I just stick to the single beam set ups.
Old Jan 28, 2015 | 12:18 PM
Take a look at these
problem with a facelift they require 4# for the dip and main beam lights.
Old Jan 28, 2015 | 12:50 PM
Racer X's Avatar
Originally Posted by OffroadFrance
Take a look at these 1x Lampada 50W H7 472 CREE LED WHITE 6500K BULB HEADLIGHT CANBUS ERROR FREE NEW | eBay
Yeah, those aren't the ones you want.
Read up here:
LED Headlights or NOT
The 1800LM version seems to be a good fit for the low beam, but leaves a bit to be desired for the high beam.
This is a 3200LM (supposedly) version. They market as 6400LM because there's two which is silly, but I digress. I picked eBay France, since you're in France and whatnot.
2015 NEW 72W 6400LM H7 Cree LED Headlight Conversion KIT Lamp Bulb 3000K 6000K | eBay
Old Jan 28, 2015 | 02:45 PM
Good read on that article RacerX, looks like for the most part HID kits are still a better way to go.
Perhaps in a few years the technology will have matured enough to make them worthwhile.
Old Jan 28, 2015 | 05:21 PM
bmeier's Avatar
I'd like to get my hands on a set of BMW Laser lights.
rambo
Oct 17, 2013 10:13 PM
AdrenalinPlease
Jan 31, 2013 05:43 PM
Spike555
Jan 27, 2013 09:44 AM
RenoHuskerDu
Oct 16, 2011 08:28 AM
s10lowrider1994
Sep 22, 2011 11:26 PM
