Led light pictures inside
Old Aug 3, 2014 | 02:37 PM
ls1morethanyou's Avatar
Default Led light pictures inside
i wanted to do a comparison on the led lights but there was none, leds were brighter all around.
below is the gallery
https://imgur.com/a/PSy4v
interior lights off, i only have two for now the rear third is on its way
interior lights on
reverse lights
head lights
Old Aug 3, 2014 | 03:09 PM
Jared9220's Avatar
those interior lights are bright!! looks good
Old Aug 3, 2014 | 04:44 PM
OffroadFrance's Avatar
Jeeeeeez, that's some joint you're smoking
Like the interior lights, they are bright compared to mine. I've used festoons with 4 LED's each and they aren't that bright but mine are quite old now and technos moved on since.
Old Aug 3, 2014 | 07:16 PM
Daedrix's Avatar
Banned
Looks good. I did something similar a while back.
Old Aug 3, 2014 | 07:43 PM
TRIARII's Avatar
Hey man please share with us exactly which LED bulbs you are using! I purchased mine from Advanced Auto and for the price I paid I expected brighter lighting but thats not the case. See pics.
Your LEDS are amazing!
Old Aug 3, 2014 | 07:55 PM
Daedrix's Avatar
Banned
I didn't use bulbs i used strips and i just tapped into the dome light harness.
Robot Check Robot Check
Old Aug 3, 2014 | 08:33 PM
That is awesome!
i got my head lights from him- you will need to buy two of them as its 1 kit(bulb and harness) for that price. i didnt know and shot him a PM and he told me about it, he threw in 2x34 led dome lights.
2014 H4 HB2 9003 CREE LED Bulb x1 Hi Low Headlight Kit 2400LUMEN Light Kit 6000K | eBay
those are his dome lights and i want more! that light is from only two of them i broke the rear housing so thats in order right now along with more feston led domelights that i found.
4X 48 SMD Panel Cool White T10 BA9S Festoon Dome Box Interior Lamp 12V LED Light | eBay
these tail lights work great, now you can get more powerful ones if you look around but my goal was to lower the electrical drain to run more leds
2X 1156 7506 CREE 5W LED Light Bulbs Backup Tail Reverse Stop Lights White | eBay
my new Vape mechanical mod was being shown off too- that vapor is thick!
Old Aug 4, 2014 | 08:10 AM
evoblade's Avatar
Just out of curiosity, what is the lumen rating of the stock bulbs?
Old Aug 4, 2014 | 01:02 PM
acg's Avatar
acg
A standard 55/60 watt bulb typically gives out 1100-1500 lumens.
Old Aug 5, 2014 | 07:01 AM
evoblade's Avatar
What's the light pattern look like? Similar to stock? I would assume so since you are using the same reflectors (housings).
