led strip running lights...
Old 06-10-2013, 07:23 AM
RANDY04D2's Avatar
Default led strip running lights...
Just installed fyreflys 24inch side emitting led strips. $12 EBAY. Cut 6 leds off each strip, fits great. Fuse tapped the 15amp engine fuse. Look great daytime, awesome at night. Using the 15 amp engine fuse, the lights are on anytime the key is in on position. Added coolness factor, when key is off the light shut off in about 8 seconds, kinda like interior lights.....
Attached Thumbnails led strip running lights...-20130609_115239.jpg   led strip running lights...-front-leds.jpg   led strip running lights...-leds-night.jpg
Old 06-10-2013, 07:27 AM
lostl13's Avatar
Looks great! I'm doing it.
Old 06-10-2013, 07:37 AM
That is the first pictures of the LED strips on an 03/04, looks great. I did a similiar install on my 99 to go along with my HID head lights.
Old 06-10-2013, 07:45 AM
RANDY04D2's Avatar
Default led strip install
Remove headlights.The plastic 2in strip under headlight unsnaps, last edge is plastic rivet, dont need to remove it, plenty of room. Strips are 3m adhesive backed. Side emitting led strips are 3/16in, and face em ourward. adhered to headlight clear plastic after good cleaning,(had electrical contact cleaner laying around,put on rag and wiped.) Fuse tapped the underhood f2 circuit. About 45min work....
Old 06-10-2013, 07:58 AM
RANDY04D2's Avatar
Default Looks good mike...
Ordered a 7.5 inch 36w newtes LED bar to fit between my $17 Harbor Freight off-road lights. $58 EBAY. Will upload pic when delivered/installed. Have off-road lights hooked up to relay to come on anytime bright lights are selected. Huge difference at night driving up north, giving the deer a chance to get the hell outta my way. After that gonna cut clear plexiglass to fit rear red fog lights and install led or halogen lamps, use them as rear work lights, hooking up trailer at night, loading the sleds, etc. Also get that annoying mini-van 3 ft off my bumper......
Old 06-10-2013, 08:06 AM
Disco_Fever's Avatar
That looks pretty slick. Nice job!
Old 06-10-2013, 09:11 AM
primussucks's Avatar
ebay link?
Old 06-11-2013, 10:58 AM
SuperSport's Avatar
I'm with you Mike. I RARELY like the aftermarket LED lights on cars. They look to cheap, kid'ish and added on. But these actually look pretty close to a stock look. Nice job finding the correct balance.
EDIT: Here's a link to the product web site:
http://shop.fyreflys.com/24-LED-LIGH...F-0603S-24.htm
Old 06-11-2013, 01:54 PM
24" 0603 SMD LED LIGHT STRIPS
Is it the ones you link to or these?
24" LED SIDE SHINE HEADLIGHT STRIPS
Old 06-11-2013, 02:07 PM
SuperSport's Avatar
You are probably right, it does say side emitting.
Quick Reply: led strip running lights...
