LED turn signals on an 00
Old Aug 18, 2016 | 11:51 AM
jesman's Avatar
Default LED turn signals on an 00
I want to move my turn signals to put on a rear bumper. I bought some off ebay with 4 wires, power, ground, low brightness and high brightness. The factory connector has 3 wires. I hooked them up with the high wire, they worked for 20 seconds and went out. Now when I try the signals I get the trailer light on the dash flashing but no signals. I went and bought the resistor kit. Can someone tell me how this should be wired to work? Thanks.
Old Aug 18, 2016 | 02:21 PM
Externet's Avatar
I would suggest to go back to original configuration first and confirm it still works that way. If some 'resetting' or battery disconnection is needed, I do not know.
As the compfuser on board that checks the draw of light bulbs considers LED lamps as almost absent load, it gets confused.
After restoring original operation, I would add the LEDs on the bumper in parallel to the existing circuit instead of replacing them for the bumper location alone.
Or, for bumper location alone, do not use LED but incandescent bulbs.
Old Aug 18, 2016 | 03:21 PM
OffroadFrance's Avatar
Check the LED lamps with a 9V battery. Some LED's don't like reversed polarity and they won't work properly if at all.
Old Aug 18, 2016 | 04:12 PM
shudak's Avatar
3rd Gear
I made my own steel bumper and simply wired in LED blinkers and ignored the red/yellow wire, IIRC.
I think I used a black and a green wire to the LED's white and black wire. I just twisted it together and tested that they worked before I soldered, sealed, and shrink wrapped it all up.
The LED's were about 6 bucks from O'Reilly's and are DOT certified and 12V
Attached Thumbnails LED turn signals on an 00-wp_20160815_002.jpg   LED turn signals on an 00-wp_20160815_001.jpg
NLAT
Mar 16, 2008 04:44 PM
DivebombInc
Jan 14, 2008 01:09 PM
dow
Nov 1, 2007 05:24 PM
2004FXD
Oct 23, 2007 07:54 AM
SpeedAgent
Jul 16, 2007 08:56 PM
