Left Rear Suspension Sags after sitting on 2000 Disco
Old Feb 10, 2010 | 06:13 PM
Murph_Dog's Avatar
5th Gear
Default Left Rear Suspension Sags after sitting on 2000 Disco
Hey gang, my first time here so be gentle :-)
2000 Disco, randomly settles on the left (driver) side after sitting... typically overnight. But not every night. Am told it's not a bag leak.
It rights itself upon start up, and I can't predict when or if it will settle down again.
2000 Disco
165k Miles
Just replaced alternator at 165k miles
Head gaskets at 150k miles
random 3 amigos (love that ABS Modulator write up-- have tried pretty much all the fixes already... even tried used modulator... grrrr)
Old Feb 10, 2010 | 07:54 PM
humroot's Avatar
2000 Disco
165k Miles
Welcome!
Who told you it's not a leak? I'm thinking that it is. Soapy water on the bag and follow the lines under the truck to the SLS pump to find the leak.
165k on original bags? if so, that rocks. Actually, 150k until the head gaskets is pretty dang good too.
Old Feb 11, 2010 | 10:57 AM
Murph_Dog's Avatar
5th Gear
"Who told me" was my ex mechanic. Or should I say "mechanic on the bubble". He said he saw the thing settle quickly, not slowly, but did not give me his rationale for why he did not think it was the air bag. I'll check with soapy water. Do I need jack it up and remove the wheel (with jack stands of course)?
Old Feb 11, 2010 | 03:41 PM
Alex J's Avatar
If you can deal with the problem for a couple weeks I'll be removing my air suspension with working air bags the end of the month. I'll sell you both bags for $45 plus shipping.
Old Feb 11, 2010 | 04:15 PM
With your mileages, you are way past due for New bags, like the ones from Arnott industries.
Sometime the ECU can cause what you are describing and only a full scan of the system will tell you for sure.
Let us know what you find.
Old Feb 11, 2010 | 05:24 PM
okdiscoguy's Avatar
Just get under your truck and wear an old shirt. You will need to spray the bags while the truck is on the ground.
Old Feb 12, 2010 | 01:48 AM
Urban Panzer's Avatar
Just replace both bags and it will be fine
Old Feb 12, 2010 | 02:52 PM
jrm123180's Avatar
I'm having the exact same issue, only it sits fine if I raise the suspension in the off road mode...
Old Feb 12, 2010 | 04:58 PM
Murph_Dog's Avatar
5th Gear
OK everyone. Looks like bags should be replaced regardless. FYI the PO replaced the fronts with coils. Not sure why they left the rears as as.... Yikes now that I know I am overdue for replacing everything I just know all systems will start failing on me :-) Alex J I may take you up on that offer. Will let you know how long we can stand it as is.
Old Feb 13, 2010 | 05:14 AM
The front never had air, its only the rear.
The rear air suspension bags should be treated as "service" items and imo replaced every 5 years MAX (3 -4 better) regardless if there is any fault or not
