Lets play "Name that Leak"
It's on the aft part of the oil pan, Goes about 1/2 way up the bell housing of the transmission. Appears to be oil and not ATF. However, not sure if its leaking or blowing back at the circular access plate on the bottom of the trans. Any ideas would be helpful. Oil pan gasket? All bolts in the immediate area appear tight.
whowa004 (03-16-2021)
@Micmac drop the plate it just an inspection plate, run a clean rag around the inside. Next you have oil all over your pan it could easily be blow back.
Clean everything up before you go to blue devil
Clean cardboard underneath
Let your engine get to temp at idle, let it idle for at least 15 minutes or so
Shut down leave it for 30 minutes or so
Now see where the oil is.
