lift kit
Old Apr 21, 2006 | 03:54 AM
discocolorado03's Avatar
6th Gear
Default lift kit
im doing a 2inch lift on my 95 disco and was jsut gunna runa spacers and swich the coils any advice?
Old Apr 21, 2006 | 10:55 AM
Landzu's Avatar
Default RE: lift kit
If your going to change the coils (springs) just get some that
give you 2" more that way you will have the axle travel also.
No need for spacers.
Old Apr 21, 2006 | 02:10 PM
jmerrill's Avatar
after lifting your disco, will it be neccesay to install different shocks?
Old Apr 21, 2006 | 10:54 PM
Landzu's Avatar
In the long run it would be better but you don't have to.
To get the full axle travel you will need to get longer brake lines
2" for 2" lift. The brake lines should be changed every ten years.
You can get the lines for about $120.
Old Apr 27, 2006 | 02:49 AM
mikemeyer0's Avatar
Just buy some 2" coils, when you can aord it and want the full articulation get the shocks and brake lines. DAP sell stainless ones at a good price.
Old Apr 27, 2006 | 07:07 PM
On a 95 D1, you can do a 2" lift without brake lines or ABS lines without a problem, you should do shocks at the same time, no since running new springs with dead shocks.
Who's springs are you going to use?
http://www.expeditionexchange.com/ is a good place for OME's
http://www.rovertym.com/ is a good place to look for springs also
Don't use any spacers and don't forget to buy a new steering stabilizer to keep you going down the road staright.
Mike
Old May 12, 2006 | 02:46 AM
6th Gear
i was just going to do the spacers for now cause its a lot cheaper and when i get the cash flow i was going to get the new two inch coil springs and the full kit and if i wanted have both and get 4 inches out of it
Old May 12, 2006 | 12:13 PM
ORIGINAL: discocolorado03
4"s won't work with most Rovers unless you want to literialy spend a fortune in replacing parts. If you have a DII you can do 3"s then you have to change out the radius arms, ABS lines, extended shocks, drive line modifications and the list goes on. Spacers will give you a lift on a weak suspension which is not a good combination off the road. When doing springs, you need to do shock at the same time or you will not be able to control the ride of the new coils.
Do yourself a favor, wait till you can afford springs and shock and have a friend elp you install them to save on labor, the end results will be great.
Mike
Old May 15, 2006 | 03:35 AM
mikemeyer0's Avatar
Save the cash and buy coils, you can get coils for around 200 bucks and get 2 or 3 inch lift, stay at 3" any mor nd you need to replace more stuff. some do some don't. get what you want when you can afford it, buying what you really don't want then replacing it later will just cost more green. look up DAP on the internet.
Old May 15, 2006 | 09:44 PM
DOHC Holliday's Avatar
ORIGINAL: Disco Mike
By "replacing parts" do you mean that as a constant need to replace, or as a one time thing when the lift is purchased and installed?
caymandrew
May 9, 2015 10:05 PM
Bostonc16
Mar 7, 2015 10:32 AM
caspian
Feb 19, 2011 06:41 PM
majrmike
Oct 9, 2007 03:13 PM
studlee
Aug 8, 2006 10:29 PM
