ABS Modulator Valve Kit vs Shuttle Valve Kit
Old Oct 9, 2007 | 01:27 PM
majrmike's Avatar
Default ABS Modulator Valve Kit vs Shuttle Valve Kit
Like many of you, I have a dysfunctional ABS Module which I am told is a faulty Shuttle Valve. The dealership of course insisted on replacing the entire ABS Module, but is now recommending the "Revised Shuttle Valve Kit". I believe this is likely the ABS Modulator Valve Kit which sells for $900 or so at Atlantic British. I had planned on simply installing the ABS Modulator Shuttle Valve Repair Kit which retails for just $59.
Any input on the difference between these kits? How do I know which I need?
Thanks all,
mike
Old Oct 9, 2007 | 02:05 PM
jdelp's Avatar
Default RE: ABS Modulator Valve Kit vs Shuttle Valve Kit
Go with the kit. Can't beat the price and it's a few hours of work if you do it yourself. Others have had success w/ that fix, and there's a post from not too long ago showing the step by step process w/ pics and all. Search for it, if I can find it I'll re-post it for you.
Old Oct 9, 2007 | 02:07 PM
majrmike's Avatar
The $59 Kit?
Old Oct 9, 2007 | 02:13 PM
jdelp's Avatar
They were $75-100 when I was having issues w/ mine, but they replaced the whole module under warranty. That was about a year ago, so they may be cheaper now. Available from the rover dealer. here's the repair link
https://landroverforums.com/m_35119/tm.htm
Old Oct 9, 2007 | 02:29 PM
sna77's Avatar
I need a new shuttle valve... see my thread:
[/color]https://landroverforums.com/m_26063/mpage_3/tm.htm[/color][/color]
OK, I just called a few Land Rover dealers... This is what I found out:
SW0500030.
Shuttle valve repair kit. $75.
Atlantic British sells these for $75: [color=#9e8354]http://www.roverparts.com/Parts/SWO500030G.cfm
Land Rover dealrs are claiming that this is not working and strongly recommend replacing the shuttle valve with:
SW0500040.
New shuttle valve. $800.
Old Oct 9, 2007 | 02:31 PM
okdiscoguy's Avatar
sna77- Check out the link for the repair kit. Doesn't look too hard, and at 1/10th the price might be worth it to try.....
Old Oct 9, 2007 | 02:38 PM
majrmike's Avatar
Can I get around having to bleed the brakes?
Old Oct 9, 2007 | 02:40 PM
okdiscoguy's Avatar
nope. Gotta bleed them every time you touch them. Might even consider a good flush if you have a few miles on it.
sna77's Avatar
ORIGINAL: okdiscoguy
yeah its really annyoing that Land Rover will not recall this... appears to be a major issue...
Old Oct 9, 2007 | 02:44 PM
okdiscoguy's Avatar
I agree. Especially since it is with the brakes. You don't want to loose ABS with these bricks.
