To lift or not to lift
Springs are going bad and putting in +2" versions don't cost much more, so here's the pro/con list I have thus far:
PROS
Aesthetics
Better articulation
More ground clearance
CONS
Less efficient driveline geometry
Higher center of gravity (roll over safety)
Power loss (w/bigger tires)
MPG loss (w/bigger tires)
Greater wear/tear on steering components
Greater wear/tear on axles
Am I missing something in the equation here?
PROS
Aesthetics
Better articulation
CONS
PROS
Aesthetics
Better articulation
CONS
PROS
Aesthetics
Better articulation
CONS
If I wasn't so tired I would argue the validity of half your "con" list
PROS
Aesthetics
Better articulation
CONS
PROS
Aesthetics
Better articulation
CONS
Was under the impression the rotoflex took a beating with a lift...maybe that's all (without bigger tires).
I may indeed "Nike" it...seems dumb not to for roughly the same price as stock (already have extended steel braided brake lines).
I used to have a 01 D2. OME HD's on the front and OME progressive springs on the back (OME Shocks on all 4 corners). It rode pretty good (had a ARB with winch on the front). If you really load it up heavy then the progressives will sag a little. If it's mainly a DD and some occasional light off-roading they're good. I ran 245 75's and the mileage difference was negligible, same on power.
I did this because I blew and air bag about 50 miles north of I-80 in Nevada. Fortunately it only blew the top off and using a few hose clamps to make a temporary ring to hold it on worked. That was the end of the air bags.
Just do it. but remember that your tired old springs right now have probably dropped down substantially so your 2" spring lift will probably give you more like 3" or higher. Either way ,I would do it. I did not notice any of your cons on my 3" spring lift. Only downside was from larger tires and it wasn't much. but again, if this is really something you are humming and haahing over then maybe a lift kit is not for you in the first place.
