Lift with SLS
Old Dec 6, 2011 | 10:42 PM
buick215's Avatar
Default Lift with SLS
Is it possible to lift our trucks and keep the air suspension or does the rear have to be converted to spring before hand.
Old Dec 6, 2011 | 11:11 PM
handsome rob's Avatar
Yes it can be done, I think Rovertym sells the lift spacers and sensor adjusters. You can then just buy front springs and the shocks. I am sure a few guys on here will tell you to covert to springs so you do not have to do it later, but for me I love the air suspension on mine and will always keep it. I tow my boa a lot with my Rover so it is nice to have it level all the time.
Old Dec 7, 2011 | 01:29 AM
bosshogt's Avatar
Yes you can do it. No need for spacers on the 2" OME lift. Just get a 1.5" spacer section from two layers of steel 1" on center water piple holder strapping. Put it on your SLS hieght sensor. Basically you are tricking the sensor to make it think the car is (higher, if I am correct?) You need one 10mm bolt and nut. It will even out your lift. I will take a picture tommarrow in daylight. Really simple and i have had it installed now for over 2 years. Cheap and bulliet proof.
Old Dec 7, 2011 | 09:15 AM
buick215's Avatar
Thanks for the help and advise. I am glad that I can keep the air suspension.
Old Dec 7, 2011 | 09:22 AM
Two thoughts, the aluminum billet is set at and angle to keep the bags level and you also nee the height adjusters cause with out them, your air bags will run at too low a pressure.
twr7cx
Sep 27, 2011 07:52 AM
humroot
Jun 7, 2011 04:34 PM
B@tt
Jan 10, 2009 05:18 PM
humroot
Mar 19, 2008 12:49 PM
