Lift with springs only
Old Feb 3, 2015 | 09:44 AM
Jnj's Avatar
Jnj
Default Lift with springs only
Can I get a mild lift 1"-2" by just swapping out springs or do I need new shocks as well? The disco I bought has new dampers so they aren't old and worn.
Old Feb 3, 2015 | 10:08 AM
Dave03S's Avatar
Yes, but when I put new springs on existing newish (10k miles on Bilsteins) shocks it did not work so well.
the shocks apparently got used to the lower ride and did nothing once lifted past their previous operating range.
I ended up having to buy new shocks again.
Old Feb 3, 2015 | 10:17 AM
WNYErikDiscoII's Avatar
Former Sponsor
You can achieve a 2" spring lift while retaining stock shocks, but you will not have much extension room from there.
Old Feb 3, 2015 | 11:06 AM
Jnj's Avatar
Jnj
This is a street driven toy to go to work and haul the dog around. It will probably never seen any off road unless we see a blizzard.
Old Feb 3, 2015 | 11:30 AM
Former Sponsor
You will most likely want some Medium Duty Springs then to retain a comfortable daily drive.
Old Feb 4, 2015 | 07:46 PM
Frank4's Avatar
No matter what springs you put under these things it will ride like a wagon on concrete wheels. I have gone through a couple different setups and the best was on a RR Classic with RTE springs and OME shocks BUT it had some pretty soft 33" skinnies. Now I say best because all four wheels were usually on the ground during normal city driving but a pothole could send you into the next lane.
The absolute worst as far as ride quality is on my DII, RTE 3" springs with Terra Firma+ shocks. The RTE's give way more than 3" and are inexpensive compared to OME. BUT the Terra Firma shocks are garbage.
Old Feb 5, 2015 | 12:37 AM
Dave03S's Avatar
The best ride I've had is with stock springs and Bilstein shocks. My current setup is bouncy. However since gas prices are down I can keep the tank full more often and it does ride better then.
The OME MD with Nitrocharger setup and no extra heavy duty add on parts or BBW's on board it bounces off of bumps in the road, there is no absorption happening at all.
Lucky 8 sells stock springs.
rchrd0413
Apr 22, 2014 02:18 PM
ATXDisco
Jan 13, 2011 08:04 AM
JBeezy53
May 9, 2009 08:00 PM
fri3daz3
Aug 18, 2008 09:22 PM
kaczman
Feb 4, 2007 04:22 AM
